Edelbrock 1406 vs 1407
Old 04-20-2011 | 01:22 AM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Transmission: T-5 Borg Warner
Axle/Gears: 10bolt/ 3.42
Hey everyone.
I am in need for a new carburetor and do not know which Edelbrock I should get. I was about to get the 1406 electric choke 600cfm until i saw the back of the package saying it was mild performance and good for cams up to 220deg.
I have a first gen 350ci with an Edelbrock EPS intake, 224/224 , .465/.465 cam, hedman headers, occasional 100 shot nitrous. I do not know what carb I should get.
I feel like the 600 is too small, as it says from on the box..
And the 1407 Carburetor says up to 230deg.. but I feel that 750 cfm might be too big.
Not sure.. need some help
I was looking to get one of these 2 carburetors because, just dont know which one
Old 04-20-2011 | 01:25 AM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Re: Edelbrock 1406 vs 1407
Also I may have some new heads put on soon.. so idk if that might call for the 750, in that case.. will I be able to use the 750 until then?
I am planning on taking the camaro for a 3,000 mile rally this summer..
Old 04-20-2011 | 04:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Get whichever one has the choke you want, and then tune it.
Old 04-20-2011 | 07:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
What's Edelbrock state about a 1405? I know it's similart to a 1406, but different. It doesn't come with the elctric choke, but that's easy to add (I have a 1405 with electric choke added).
Old 04-20-2011 | 09:49 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i have a 1405 with electric choke, 1406 and 1405 ,they are both 600 cfm and pretty much the same except the 1406 is calibrated for fuel economy and the 1405 is a little more calibrated for performance.
Pac J
05-17-2020 11:44 AM
armybyrd
Carburetors
10-20-2015 04:57 AM
skinny z
Carburetors
09-30-2015 12:25 AM
efiguy
09-27-2015 02:30 PM
Night rider327
09-25-2015 05:47 AM
