Geometry Corrector for TV Cable?
Car: 1992 25 Anniversary Chevy Camaro RS
Engine: TBI 305sb
Transmission: 700R-4
Axle/Gears: Stock
Where would I find a geometry corrector for the TV cable when I drop in my carb 350?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Geometry Corrector for TV Cable?
They are carb dependant, so depends on what carb brand you get. But summit sells, and has their own brands now for $21.
http://www.summitracing.com/search/?...orrector&dds=1
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
What carb are you using? I have Holley, got mine at JEGS....
I am using a quadrajet that was off of a stick, so I needed a tv setup. You can research this subject and find it easy. I don't remember the sight or I would give it to you. If you can buy the linkage for cheap, I would just do that.
Engine: TBI 305sb
Axle/Gears: Stock
Jegs or Summit have the correct one...
Engine: TBI 305sb
Axle/Gears: Stock
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
