What carb
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
What carb
i have a SBC 350 with dart iron eagle platinum heads. 200cc and 64cc chamber. Edelbrock performer intake, Edelbrock TES headers, and lunati 60103 cam. I currently have the edelbrock 1406 carb which is 600cfm and im pretty sure its not gonna be big enough what carb size and brands do you guys suggest?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
First, what are you using the car for? Cruising? Daily driver? Track-only? Street/strip?
You have pretty big heads with a fairly large cam. The powerband advertised by Lunati is 1800-6200 RPMs. The standard carb CFM formula is CID times max-RPM divided by 3456. Plug your numbers in, it comes up to 627 CFM. That assumes 100% volumetric efficiency (rare) and single plane intake manifold. You have a dual plane intake, which effectively splits the carb in two, meaning a little larger carb is usually required to get max power.
If you are primarily racing the car, then get a 650 double pumper Holley. If you're only cruising with it or driving it daily, your current carb will suffice.
BTW, your intake manifold is a mismatch with your cam & heads. You should be running a Performer RPM.
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: What carb
and yea i do have a mismatch intake i dont have these parts on yet just getting everything rounded up before it goes on. I have the EPS intake which is only to 5500 rpm so ill be looking for the rpm one
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: What carb
yea around a 2600 stall and yea built th350 with full manual VB gears im unsure on but am looking for a posi and around 3.73 gears
1 Post
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: What carb
I know some people would disagree but I would do a Holley 750dp. My car has a 750dp/HP and a Weiand team G single plain intake and I wouldn't change a thing but my car is not a daily driver.
Mark.
Mark.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: What carb
I run a 750 on mine as well. Only difference is I have an Airgap RPM. Aside from that - everything else is identical to his build for the most part.
Re: What carb
i had an arguement with a good friend of mine because i wanted to run a 750dp. he told me that the 650dp i have now is plenty for my motor. and i have fully ported heads also
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
