how to rig up electric choke
Car: 85 Z28
Engine: 327
I have a carbureted 327 in an originally tpi car. I need to hook up the choke. How do I go about doing this. Simplist way would be appreciated
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: how to rig up electric choke
t-tap it off the heavy pink wire for the coil.
that will give you keyed power.
Car: 85 Z28
Engine: 327
Cool. Thanks. And do I just take like a piece of 12 gauge and hook it to plug on choke then hook into pink wire within the bundle of dizzy wires?
Car: 1988 iroc-z
do you have the big cap dist or small cap
that year had both
that year had both
Car: 85 Z28
Engine: 327
It is an after market HEI vacume advanced didtributer.
Car: 1988 iroc-z
either way.......
it will be a 12-14 ga. pink wire that used to go to the coil (if you had the small cap) or dist. B+ (if you have the large cap)
Car: 85 Z28
Engine: 327
Car: 1988 iroc-z
so you should have ran the pink wire in the car to the B+ on that dist.
the car runs,right?
the car runs,right?
Car: 85 Z28
Engine: 327
Yes. Car runs great. The car had the motor and carb setup in it when I got it. I have not gone through everything yet, but I know it has a lot of wires running into distributer. Like I said, it was originally a fuel injected car so I am still sorting the bugs out. But it starts usually as long as it is not to cold, but I am sick of reving it for ten minutes to get it warmed up, so that is why I would like choke to work. Plus it idles a lot better when it works
Car: 1988 iroc-z
ok to shorten this up,they should have used the original pink 12-14 ga. wire to the B+ on the dist.
if they didnt,you will just need to find the power wire for the dist. it will be the heavy one. check it with a test light that it only has power with the key on.
and thats the one you tap for the choke.
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
The wire you plan on splicing it into cuts down to about 7volts after the car is initially started. May affect choke operation?
Car: 1988 iroc-z
Car: 1991 Chevy Camaro
Engine: Chevy 305 bored .30 over
dont hook it up to anything igntion related. youll fry the choke coil. the could over heat
Car: 1988 iroc-z
this thread is funny lol, anyways, sorry for hi jacking the thread but
im having sorta the same problem except my original choke wire is dead now. idk why im not getting power from it. can i just tap into the same pink wire? i have an 84 ta.
Car: 1988 iroc-z
yes,its a common problem. the factory wires the choke in with the oil pressure switch.all that it prevents is the choke from starting its opening process without the motor running,ex. you go out to your ice cold car,turn the key forward and play the radio for 15 minutes without the motor running,then decide to start it.the choke will have fully opened and the motor is still cold.
THAT IS NOT LIKELY TO HAPPEN
(worst case,turn of the key for 5 minutes and the choke will reclose)
so just tapping the key on power feeding the dist. is a easy and reliable fix.i have done it to my own cars,and customers(especially when upgrading the old heat riser style choke to electric),and never had a problem,also the choke coil draws less than 5 amps .
i love the comments by people who know nothing about cars.
Car: 1988 iroc-z
i can provide you with the factory wiring diagram if you want to pinpoint it the "correct" way.
regal 301,
you do the choke thing for a living or the asshol thing for a living??
good to know but all assholing aside thats good to know cause the noob at summit said anything ignition would fry it. Saves me running wires through the firewall....
TMZIrocZ350
10-07-2015 12:09 PM
