fuel line - pump to carb help
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
It's a 1986 Firebird 305 qjet. Will this line work for going from the pump to the carb? http://www.classicindustries.com/cam...s/fgl8508.html
I don't know what one looks like and I don't know the fitting size or anything I need help.
Re: fuel line - pump to carb help
This one looks like it would be easier to install. Could I use this to replace the whole line? Can I just screw on the fittings and screw them into the pump/carb?? nothing special required??
http://www.summitracing.com/parts/SUM-TANKKIT2/
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I hope we're talking about a mechanical pump mounted on the engine. If so, this one should work http://www.summitracing.com/parts/SUM-G3150/ . Available in different colors if you add a suffix.
Car: 85 Z28
Engine: 327
Hey five7 . Saw that kit but said was for pre 74 qjets. Is that jsut words , or is there a kit for post 74
Engine: LS1/LQ4
The difference may be the nut that goes into the q-jet fuel bowl. Shouldn't be a big hurdle.
theshackle
03-05-2017 06:37 PM
NBrehm
08-25-2015 11:49 PM
beachrodder
08-25-2015 08:05 AM
AkDrifted
08-17-2015 07:45 PM
