Edelbrock 750 cfm won't stay running
1 Post
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
So I just took off my 600cfm from my 357, car ran like a dream but I felt it could use a bigger carb. Just put on a 750 and can't get it to stay running to save my life. Adjusted both needles, no vac leaks, 6psi at the carb. Stock cam. What's going on?!
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Re: Edelbrock 750 cfm won't stay running
possibly stopped up idle circuit. 6psi vac sounds rather on the low side for a stock cam.
1 Post
Yes 6PSI fuel pressure, sorry for not stating that.
The car starts, but immediately dies. If I give it gas it'll stay running but barely. This is a previously used carb unfortunately, but I took the top part of the carb off and checked float levels and anything else of the obvious, found nothing. Took the needles out and blew air in their multiple times, still nothing. It's as if the needles aren't even making a difference.
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
sounds like a rebuild is needed. What was it used on before?
1 Post
Well turns out it wasn't the carb. I bought a brand new one and it was doing the same thing. I had vac leak at the back of my intake. Got another 600 and sold the 750.
86IROC112
08-17-2015 02:00 PM
