Quick Fuel SS vs Q series
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Ok guys i changed my decision on carbs ( again ). Originally it was going to be a holley DP 750 mech secondaries. Now i think am set on the quick fuel carbs, i love the way they look and they get nice reviews by eveyone. Which brings me to the question for the experts.
Q series are running roughly $100 more then the Super Street series. Seeing i know nothing about carbs, can someone explain in simpliar terms why it is better? Will the Q series be an overkill of the SS series for my application? Motor list is here
https://www.thirdgen.org/forums/engi...-383-swap.html want to average 500fwhp, eventually 150 shot down the road.
if any how much gains am i talkin between the 2? running a 1inch spacer aswell. If its 5 or 10 hp then ill go with SS, if its 5-10hp but Q series is better with throttle response etc ill prob go with that.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Quick Fuel SS vs Q series
I'd personally go with whichever one had annular boosters, regardless of choke option.
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
would think an electric choke would be more. So Q series is no choke, SS is choke, any other differences between the 2?
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
which one you look up? All the Q series i seen were 620+ and SS series 540ish.
I just dont want any downfall in parts, i went all out ( too me ) on this build rather then my original budget plan, i want a decent carb that will put a on my face
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Just a picture for reference I went with the 750 on my modified 355. I think your 383 will love it.
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
i've read acouple post saying non choke carbs flow a tad bit better, the the flow would seem insignificant to someone. How much flow difference you talking?
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
ok, what you guys think about this one, bout to order it wanna make sure its good
http://www.quickfueltechnology.com/c...-cfm-drag.html
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Well next motor is gonna be a totally different setup. Am gonna jump on the band wagon and go LSx
But back on topic, great carb? anything better for the price, overkill?
1 Post
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
You will love the Q-750 1 of the best carb I ever had. post some picks when you
get it set up. For my motor set up my jet size 78/89, nozzles 35/38, accelerator pumps are 30/50. I also have 2 other quick fuels carbs.
pics Q-750 next to Holley 735 cfm
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
you can follow my build thread at the engine swap forums if you want, ill post up the jetting size there
hectre13
12-11-2023 08:14 AM
theshackle
03-05-2017 06:37 PM
hectre13
08-26-2015 08:17 AM
Navy8125
08-25-2015 08:25 PM
knight72
08-10-2015 09:32 PM
