Fuel Pressure psi/ Timing
Car: 86 Transam / 80 Transam
Engine: 86/355 lo5 80/68' GTO 400
Transmission: 86/700R4 80/TH400
Axle/Gears: 86/3.42
Got a bypass fuel pressure regulator. on my new Lo5 350, .30 over with 86" l98 aluminium heads, a zz4 roller cam/ 1.6 rockers and edlebrock performer intake w/ 750 Edlebrock carb manual choke and serp setup. Just wondering if anyones had this setup and whats a good psi for the fuel pressure reg. and what to set the carb idle screws at right now there at 1 1/2 turns out for initial start up and also whats good for the timing with a 65K HEI dizzy. I've had it started but I had the wrong fuel pressure regulator and it was running to rich and fouled my plugs out and basically just ran like ***.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel Pressure psi/ Timing
Carbs won't reliably take much more than 6.5 PSI or so.
Set the timing for a fully-advanced 34-36 degrees at 2500 RPM or so, and as much vacuum advance as it'll take as soon as it'll take it without pinging under part-throttle acceleration.
Tune the idle mixture just lean of where you have maximum vacuum at idle speed.
1 Post
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
That is very true, esp. under heavy/any direction g-force,
AFB is not an easy bowl to manage.
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
