Carb Caught Fire
Old 08-11-2010, 10:35 AM
vindennl48's Avatar
Car: 1987 GTA Trans Am
Engine: Carb. 305, bored .030
Axle/Gears: 3.73 posi
Carb Caught Fire
I have a 305 with a carter afb 4 barrel carb on it.
It will only backfire when its sitting at idle and i try to punch it slightly. It happens about once out of ten times. It actually caused my carb to catch fire and I had to get a policeman put it out with an extinguisher. I took apart the carb and cleaned the whole thing top to bottom, the gaskets still looked good (rebuilt it about 4 months ago), put it all back together and its still backfiring.
The carb is a little to big for the engine, I believe? its a 650cfm carb.
So, what I have read is that my timing is off or I am running too lean. Would that make sense for my situation?
Sorry, I'm a little new at carburetors.
Old 08-12-2010, 04:22 AM
DoubleV's Avatar
Re: Carb Caught Fire
Yes.
Old 08-12-2010, 04:26 AM
EvilCartman's Avatar
Car: '82 Z28
Check the timing first and yes, could possibly be a lean pop. Haven't had one fart fire at me for a long time but it was usually a timing issue. Also, I hope you're not using one of those foam triangle air cleaners...
Old 08-12-2010, 08:23 AM
vindennl48's Avatar
Yes, originally it was the edelbrock one . I took out the foam because It has a gaping hole in it from backfiring already. I have mesh inside the air-ram so I figured it would be safe till I came up with an alternative.
Well I figured out some of the problem.. One of the studs holding down the carb and spacer were completely stripped out. So I got new gaskets and all new studs and nuts and it hasn't backfired on me since. Just need someone to tune the carb.
Thanks for the help
Old 08-12-2010, 10:17 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check all your plug wires, make sure there's no shorts or breaks in them. Make sure they are all securely on the plugs and dist. Recheck firing order. In my experience, backfires are usually an ignition issue, not a fuel issue.
Old 08-12-2010, 01:18 PM
Heavy_Chevy's Avatar
i just yesterday cleaned the rotor button and cap on my sisters 83 monte carlo 305...i had to take off the plug wires...and when i put it back on i had 2 wires swapped around....it idled fine and ran but when i punched it at idle it would backfire...you might make sure that your plug wires are right.
Old 08-12-2010, 02:11 PM
vindennl48's Avatar
I checked the firing order and it looks good. And they are all secured to spark plugs and distributor. Tonight I'll run a continuity test on all the wires to check for breaks in the wires, there is no visual cracks or breaks.
Would old spark plugs cause backfiring? They look like they could use a replacement..
Also, it has a 650cfm carb on it. What I've read is that for a 305, you should really have a 500cfm or 550 at the most.. would this also cause backfiring because the vacuum created by the carb isn't working correctly for the motor?
Old 08-13-2010, 04:41 AM
Car: '82 Z28
650 will be fine, I ran a 750 on my 305 without a problem for a few months before dropping in my current 350. What's you're timing at?
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
camarohelp
09-22-2015 03:19 PM
WickedBowtie
09-11-2015 11:24 PM
fasteddi
09-10-2015 09:32 AM
Wylecoyote08
09-08-2015 08:26 AM
Quick Reply: Carb Caught Fire
