Need a vacuum source
Car: 1991 RS Camaro
Engine: 400 Smallblock
I need to find a place to run the HVAC controls off of so can I get vacuum from either of the 2 outlets on the front of my carb? One is a ported vacuum outlet and the other is for the PCV valve and is pretty huge. Although its unrelated to carbs, if I can't use any of the above sources could I put a two way splitter in the vacuum hose that goes from the intake manifold to the brake booster? Or would that cause me to go screaming into a tree...
Car: 1991 RS Camaro
Re: Need a vacuum source
I believe I may have found the answers to my own questions, but I'll post what I figured out just to make this a worthwhile post in case anybody else has a similar issue.
The ported vacuum output won't work very well for something that needs a vacuum supply at idle because it sees no vacuum at idle. I'm not sure about the PCV output but it doesn't seem like a good idea to me. I found a picture of another car that had a tee screwed directly into the intake manifold that split the vacuum two-ways, between the brake booster and the check valve that supplies vacuum to the HVAC controls and the vacuum resevoir ball thats under the drivers side fender. Heres the parts I found on Summit, first is the tee that screws in and second is the straight pieces that screw into the tee that allow you to hook a vacuum hose to it. Stainless steel ones are kinda pricey though.
http://www.summitracing.com/parts/PRS-1042/
http://www.summitracing.com/parts/PRS-1044/
Go to the boneyard and get the vacuum port piece from the rear of the intake on any Olds 307. They have 2 'outlets' on them and would just replace the single outlet of the one in your pic. I assume the threading is the same.
Alternately, run a cheap plastic vacuum T and you should be fine.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll also need a vacuum canister for the HVAC controls. Your 3rd gen came with one, it's a plastic 'orb', it's located under the driver side headlight - you have to get at it from under the car, taking the plastic cover off. You want to T off the intake vacuum source, with a line that runs to the 'orb' with a check valve, and another line that runs to the HVAC controls. That way, when there's low vacuum, the HVAC controls still operate using the vacuum 'stored' in the orb.
Pac J
05-17-2020 10:44 AM
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
HoosierinWA
10-07-2015 10:15 AM
