TPI To Carb, Understand the basics, Still need some clarification.
I am still at a misunderstanding as to what i should do for a fuel pump/fuel lines. My stock pump i just replaced a few weeks ago. Also intakes, my car is an 85, do i want the pre 86 intake or the 87 up?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Pump - your choice: Use the in-tank electric with a return style regulator; or drop the tank, remove the in-tank, use an engine mounted mechanical.
Intake - is the engine original, or has it been replaced? If it's original, you should be able to figure out if '85 is before '86, or after '87.
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
