Swtiching to carb, NEED HELP PICKIN DISTRIBUTOR.....
Car: 86 Z28
Engine: 350TPI
Transmission: 700R4 lookin for shift kit
Axle/Gears: 3.23???
MSD STREET FIRE HEI............. OR PERTRONIX HEI COMBO 1R (INCLUDES IGNITION BOX)
I want the MSD, but the Pertronix is mutiple spark... but I rather have the MSD, but my question is will I need a ignition box? I read up and found out the MSD is only one wire hookup....
thanks in advance
thanks in advance
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Swtiching to carb, NEED HELP PICKIN DISTRIBUTOR.....
that msd distributor is just a stock replacement. you wont need a box with it.
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
thanks
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Make sure the distributor gear is compatible with your camshaft. I went with the GM performance HEI with the melonized gear (compatible with my roller cam). I am happy with it for the price.
Car: SOLD!!!!!
stay away from the pro comp distributors. many people have had problems with them over time. i replaced mine with a msd distributor and it runs way better.
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
