quadrajet info needed
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
can somebody measure the throttle arm on a quadrajet carb from the centerr of the arm to the kickdown nipple for me PLEASE. i cant find info anywhere and im having trouble with my kickdown cable with my edelbrock carb. thank u
1 Post
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: quadrajet info needed
I measured for you. 2 and 3/4 from the top or 2 1/4 from the center of the throttle mount. Also a picture for you from from a 1980ish Q jet carb with a tape measure so you can see yourself.
http://s681.photobucket.com/albums/v...t=Qjetinfo.jpg
1 Post
Engine: 355
already bought the one for carb and the adjustable one...
1 Post
Engine: 355
http://s681.photobucket.com/albums/v...=Qjetinfeo.jpg
1 Post
Engine: 355
anybody use the spectre adjustable bracket for the throotle and kickdown? will that help me get more out of cable since i dont thimk its pulling it out far enough?
1 Post
Car: 1983 Z28
You are welcome.....I had read quite a few posts about this issue when I did my build, I have an edelbrock intake with a stock Q- jet throttle bracket, I did have to use some washers as shims to get the right angles, but it works good.
Good luck getting yours lined Up!
