what brackets to use on this carb
Car: 88 iroc
Engine: 350 bored .40 reman vortec heads
88 iroc had tpi in it now have a carbed 350 I have looked but cannot find a definate answer in my searches. the carb is a holley 4777-4 650 double. Can i use the stock cables ? and what cable brackets do i need ? everyone has been a great help on here so far thnk you to all
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: what brackets to use on this carb
you can use a universal bracket but i always have to modify them to work correctly. since camaros came with carbs, the cable for a carbed engine will work.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I used a Spectre universal throttle cable and bracket for my carb swap. They're not that expensive, can be found at most auto parts stores, look pretty good, and work great.
Car: 1990 Camaro ZRS
Engine: 350 SBC
holley makes the brackets you need for the tv cables. and it is a good chioce if you have a 700R4 tranny. these holley brackets are crucial for the overdrive of the 700R4.
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
im in the same situation. someone suggested holley part #20-88 to me. havent got it yet though. let me know what you decide on.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I just recently switched from TPI to a Mighty Demon. The stock cables will work...with some modifications. First, you need the 700R4 geometry corrector that goes on the carb linkage (I used a TCI). I then bought a swivel mount for the throttle cable to hook to the carb linkage (I believe MR. Gasket makes them). I had to cut the swivel mount to get the TPI cable to fit inside it (the end of my TPI cable looks like a barrel). It took about 30 seconds with a Dremel. I purchased the universal bracket to mount the TV and throttle cables to the carb baseplate. After much modifying, I threw the POS in the garbage. Don't waste your money. I am going to make my own from some aluminum sheet stock this weekend. Lastly, the travel on your gas pedal may be a little too much for the carb linkage. Too many stomps to the floor and something could bend. I am going to put a possitive throttle stop on the pedal linkage. This was with my BG...Holley may not be exactly the same. Also, my car is a 1990 IROC, so it may not be exactly the same.
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
I used the edlebrock bracket but then again i have an edelbrock carb. Def. be sure to get that geometry corrector Overdrive Bowties will be able to help you out. And the cables obviously can't be re-used (i had my head up my ***, sorry)....im gonna purchase a detent cable & throttle cable for 1990 305 TBI car to use with my edelbrock....
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
