PCV Valve/Breather Vacuum Question?
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Do you have to run a PCV valve or can you block off the vacuum nipple?
I simply just dont like the looks of it, i have edelbrock elite valve covers, each with only 1 whole in them; i have a oil fill cap on one and a air filter breather on the other.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: PCV Valve/Breather Vacuum Question?
yes. cap the nipple
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
As long as the motor can breathe it will be ok the filter on your valve cover will cover it.
Car: 82 Firebird
Engine: Boosted LSX
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can cap it off, but you really want a working PCV system.
vacuum can increase HP but the pcv is just air flowing through the crankcase. i think the pcv system may increase windage, but thats just my opinion, i have no proof.
Car: SOLD!!!!!
the pc system pulls excess crankcase pressure from the engine that builds as it is running. its best to have one. can be run without it. but i wouldnt do it. especially if it is mostly street driven. if it is mostly a race car then it can be done away with.
Car: 82 Firebird
Engine: Boosted LSX
But wont a straight up air filter breather do just fine at letting the crankcase pressure out?
i've been drving my s10 for almost 3 years, every day, avg 20mi., and no problems other than a very very small front seal leak. not sure if its related. i think the pcv system is mostly to keep crankcase vapors out of the atmoshere...AKA emissions......thats my opinion i have no proof other than my own personal experiences. dirt track racers sometimes run very long races and only use breather filters.
Car: SOLD!!!!!
my oil leak may or may not be from the lack of pcv. i'm just saying if you have some kind of vent you should not have a crankcase pressure-related catastrophic failure.
Car: SOLD!!!!!
no not catastrophic failure. just like stated above. acids eroding the engine away over time. a lot quicker than without it. trust me i have seen it within my 23 years in the field.
well, i know until the 2007 diesel emissions standard all/most diesel engines just vented to the atmosphere. if any type of engine would suffer from contaminated oil it would be a diesel engine. you know, 22:1 compression ratio an 30,000 psi fuel pressure at the nozzle tip.
i can do this...the oil in my truck has at least 1000 miles on it. i'll take a sample, pay the $20 and have it analysed and post the results.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A working PCV system will keep your oil cleaner longer by sucking out harmful fumes before they become harmful oil contaminants, keep the inside of the engine in a negative pressure which can help oil aeration, it helps ring seal and helps to keep various 'problem' gaskets from leaking... like oil pan and valve covers, and it keeps the outside of the motor and engine bay cleaner by keeping away those oil fumes that just 'vent' all over everything.
Its got SO many more benefits than just being an emmitions device... you'd be wise to keep it functional. PCV valve on one valve cover, breather cap on the other. Or be like me, cut a hole in the back of the manifold where it only covers the lifter valley (not into a runner) and put in a grommet and PCV valve, then a breather in each cover. This is basically what GM did on the LT1. Looks much cleaner, and works beautifully.
Car: 82 Firebird
Engine: Boosted LSX
Can you take any pictures of this? I guess im just turned off by the looks of the PCV as this is going to be a show car but i am going to drive it so i dont wanna do that much harm to the motor if i could prevent it.
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
if you're not going to run a pcv valve then you really should run another breather. if not vacuum created on decel will suck in gaskets and cause oil leaks, only one way for air to get in or out. and diesels have a legitimate reason for still running drip tubes, seeing as they have no throttle blades and therefore create no vacuum to operate a pcv system.
1 Post
This is an intake I did this with a few years back.
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
that is a nice setup. i have 2 breathers and was wondering about a pcv. i like that setup alot.
1 Post
Basically none. It just sucks fumes out of the lifter valley, and fresh air comes in through the valve covers - and theres alot bigger 'gap' between the lifter valley and PCV valve with that setup, then there is between the rockers and PCV valve if you put it in the valve cover.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
What grommet did you use for that and where would I find one?
Also what vehicles came with a straight pcv fitting like that? All the ones I have seen are 90*.
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
Just my two cent worth... The engine does not need fresh air in the crankcase or valve covers. The best method is a PCV in each valve cover. Fresh air equals moisture which is not good in an engine. It will condense in the oil and start to break it down. No PCV's guarantee your oil will turn to sludge. Just my two cents. Dorman sells a grommet for about $5. Also putting a vacuum on the crankcase is a good thing. If you have an air breather you can watch fumes come out the breather. Solve it with science! The crankcase has positive pressure. The valve cover with the PCV has vacuum(negative). The pressure will flow to both the vacuum and the atmosphere (zero) in the breather.
- The PCV system needs fresh air to function.
- Engine oil gets hot enough to "boil off" any moisture provided it is run long enough.
Car: 1982 Z28
Engine: 5.0L
Why do modern engines run 2 PCV's and no breather? My F150 has that setup and clean oil. If modern engines do it, why not try it. No engine pulls vacuum hard enough to "suck" gaskets in. If it did you gaskets were old or not installed properly.
Someone present a logical, fact based reason for not using two PCV's and no breather.
Lots of race engines run two PCV's or vacuum pumps to create vacuum in the crank to help the piston return to BDC faster. Faster / easier revving = more power available sooner.
This is not a PCV system however. For the concept of a PCV system to function, it is nessisary to have a breather. Pulling a vacuum on an enclosed space with no inlet does not yield ventilation. That's just logical. For air to flow IE ventilate the crankcase, there must be somewhere for it to flow from.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the "positive crankcase ventilation " system removes harmful fumes that otherwise would contaminate the oil. and it looks as if you have some major coin in it. do you really want to do anything that would shorten its life???
Remember, this thread is very old, I was simply trying to get a response out of Adam when I asked what grommet he used for his carb PCV setup he showed in a picture.
Car: 1982 Z28
Engine: 5.0L
Keoman... the pressure in the crankcase comes from ring blow by, which is constant. Pressure will flow from high to low. The engine vacuum will not pull fresh air in. Crankcase gas will leak out the breather.
Remember the original setup of PCV. The so called breather side went to the air cleaner with a small filer that was always soaked with oil. It was a **** poor design.
Remember this design comes from the 70's when emission control had just started. Do you really think that this system has not been updated or re-engineered?
You can run a breather. You don't have to use a PCV valve. But it will shorten engine life.
Logic and facts please.
