holly or edelbrock carb????????
Car: 1992 Camaro Z28
Axle/Gears: factory 373
ok heres the deal. i have a 92 camaro z28 and i took out the 305 tpi to put in a 350 carb...no ecu
everything is edelbrock on my car, manafold, rolling chains, water pump, cam, fuel pump,....and all my chrome parts.
the onlyt hing i need now is a carb. now im thinking about going with edlebrock 750 eletr choke.
i know how to use them and will match the rest of the car.
but im hearing from alot of sources that i should go holley,....what do you guys on my trusty forum think?????????? note- i have no clue how to use them, adjust them.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: holly or edelbrock carb????????
If you're more comfortable tuning it, then by all means go with the Edelbrock. The idea that it "matches" the rest of your parts better than some other brand is just marketing hype, though.
I'd pick the Holley as the better carb, personally.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
id have to say holley. ive used them for years and still love them. i had a buddy with an eldelbrock relacement and i never could tune it right. so imo go holley but thats cause ive had bad luck with edelbrock
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
I'd go holley too. Easy to adjust and tune.
codeysabatini
11-10-2015 04:07 PM
sreZ28
10-22-2015 08:21 AM
305, camaro, carb, carberators, carburetor, carburetors, common, edelbrock, fuel, gen, holley, holly, pump, swapping, witch
