Edelbrock Rocks!!
Car: 84 trans am
Engine: 305 carb
Edelbrock Rocks!!
I have a 84 trans am 305 all stock and had trouble with carb flooding, white smoke on start up just not idleing right. So i had it rebult spent about $200 to get the job done start to finish. Car worked little better but still not like it should. I was thinking if it was something other than the carb making the car work bad. 6 months went by and i have not been using the car much so one of my friend said try and get another carb so i did a edelbrock 1406 on ebay. This is a whole new car. starts right up idles awsome no flooding and no more white smoke at start up. I am really amazed its like i have a new motor. my friend and me put this carb on and all we had to do was adjust the choke and thats it.THESE CARBS ARE GREAT!!
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Edelbrock Rocks!!
if you were using a electronic rochester...yeah i had the same problem. out of the blue it would start smoking black and stall. i also went with an edlebrock to fix the problem. they are good a replacement for a daily driver but thats about it.
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
I'm having nothing but problems with mine, mine keeps running rich. Trying to get it leaner, but now I lost one the rod springs.
most edelbrocks cant take more than 5psi fuel pressure
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i replaced my holley with an edelbrock a while ago ...it runs great!,,i don't need to constantly adjust anything ,,,edelbrocks for the money ,,are worth it....and yes edelbrocks run best with 5-6 max psi fuel pressure,,,just get an inline fuel regulator and set it at 5.5psi and it should run like a charm...
Car: 84 trans am
Engine: 305 carb
I was just woundering how many people here are running Edelbrock carbs and what size ? THANKS
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
I am very happy to hear that you are happy with your edelbrock carb, and getting it used I imagine you got a good deal on it. I agree that there is no carb better at bolting on and running good than the one you got.
I will have to say, that I disagree that they are a "better" carb than a q jet or holley. A q-jet can be tricky for some people to set up right, and a lot of people that "rebuild" them might as well drop them off a cliff.
I guess people choose there favorite carb from there own personal experiences, and there is enough junk out there to make anybody hate any one of these carbs, but if you get a good one of any of these carbs you will be happy.
And as far as "constantly adjusting a holley,"If someone is constanly adjusting one, then they just have never got it right yet, these carbs are as good for daily usage as any when they are in fair shape and adjusted right.
1 Post
Car: 87 Camaro
I have a 1406 and I love the thing. I poured slushie down it a few months back and it doesnt idle quite right now (that stuff is like syrup) and let it sit for a few days before I started it again which was probably a bad idea. I get 26mpg highway though
Car: 84 trans am
Engine: 305 carb
bart91406, hey i total agree with u on that. if i had got a holley and bolted it on with no problems i would be saying the same with them but i have to disagree with u because no where did i say edelbrock carbs were BETTER than any other ones out there. which carb are u running?
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i have 750 cfm edelbrock performance carb on my 67 with 468 and 177 weiand and it runs pretty good, i do want too change it 850 holley or something of that sort eventually. My T/A was originally a TPI so i'm keeping it fuel injected..
Transmission: T5 WC
i have a 1405 600cfm with electric choke on my 350...it's bolted to an edelbrock performer rpm intake...it runs fine and i like it....bolted it right on out of the box!!
i also never said edelbrocks are better than a Q-jet..or even a hollley...i just simply said for the money and if your not a person who needs to overspend or are on a budget ,,,an edelbrock is a good carb for the money ...it can do anything any other carb can as far as gas mileage and performance..it just needs to be tinkered with for mods.. ...again , it's a great carb for the money....just my 2 cents.
My Edelbrock 1406 runs better now that I've leaned it out 2 stages from stock. I'm still getting a lean spot in part-throttle though, causing the car to over-heat. I'm just thinking that there's some junk caught in the main jet circuit that I can blow out when I take it off.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i've had a 1406 and a 1411 on various setups and found both of them to be complete crap, cant tune the secondairy air valve, alwaysw run rich, never took WOT well.
have a modified 750/4150 holley now, have never had to adjust it, and it works like a dream.
Transmission: T5 WC
it's funny how some people hate ededlbrocks and some love them ...i guess it's just if someone had a good or bad experience with edelbrock carbs...
1 Post
Car: 1987 camaro lt
Engine: soon 383
have the edelbrock on my camaro took it out of the box put it on the car and have not had to touch it in 7 years.. on my stock cars i have Holley and I'm always messing with them most of the time its the weather cold one night not the next. but i like them both but on my street car edelbrock all the way
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Most of the time, it's the level of understanding of the carb that is the deciding factor. If you're willing to learn about them, any of those carbs can be made to function reasonably - as long as it has hope of working on your combo (a 1050 Dominator isn't likely to work at all well on a stock '82 LG4, for instance).
Having said that, I know of two racers who went faster with an Edelbrock carb than they did with something else. In one case, a guy went from an Edelbrock to a Demon, couldn't figure out how to tune the Demon (not convinced he tried that hard, and this was in the time period when members here were reporting quality problems with Demon carbs), put the Edelbrock back on and was happy (haven't seen him at the track for about 7 years). In the other case, a racer had a cobbled together Holley that he kept messing with, bought a new Edelbrock and picked up a few tenths. He then blew up the engine (age old story of an engine running best just before it breaks). He never tried a new Holley or known-good Holley.
All other cases, it's been the other way around - the Edelbrock was slower. This forum is filled with Edelbrock problem threads (as well as Holley and q-jet). There are probably more threads with unresolved Edelbrock problems than of the other types of carbs.
If you have a functioning q-jet, it makes absolutely no sense to replace it with an Edelbrock.
Personally, I have no love for them.
Glad the OP's is working out for him.
Transmission: T5 WC
i agree with you ...if you have a functioning q-jet ..keep it on...but if you don't ..and want a decent carb for not too much money ...an edelbrock is a good choice..
Car: 1985 Pontiac Trans Am
Engine: 305TPI
1 Post
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
i'm running an edelbrock 1406, i'm sure it works just as well as any carb that is tuned properly. I only bought it because it was on sale. If a holley was on sale i would have bought that and learned how to tune it. I spent 1 day tuning my edelbrock, using a wideband O2 sensor makes it easy to find what rods and jets to use.
Car: 84 trans am
Engine: 305 carb
what wide band did u use and how hard are they to use?
Car: 1994 Z28
Engine: 355 LT1
I have had nothing but good things about these carbs but I'm a holley guy. (my buddies goof and say I'm not a true chevy fan cause the holleys came on fords).
I think if you don't have to tune your carb, you aren't running at full potential.
I never used a wideband with a carb, but I did use it with my piggy-backed EFI setup on my old car and it plugged into the GReddy Emanage Ultimate easily. The EFI recognized the input and I could tune the car during driving for all conditions.
Of course tuning a car isn't as easy since you have to open the hood, but you can still tune it easily. Get the Innovate Motorsports LC-1 and a gauge and you can watch your numbers while you drive and when you get home you can tune it whichever way you need to.
Pac J
05-17-2020 10:44 AM
efiguy
09-27-2015 01:30 PM
Night rider327
09-25-2015 04:47 AM
