which air cleaner will fit great?
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
* stock iroc-z hood
* Edelbrock performer RPM Intake
* Holley 650 Double pumper
* Hei distributor
Which air cleaner SIZE will fit great with this setup?
14 inch / 11 inch / 9 inch ???
drop base??
i need to now before i buy the wrong parts!
i only need the sizes which fit the best
thanks all dennis
* stock iroc-z hood
* Hei distributor
drop base??
thanks all dennis
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Got to be drop base.
Spectre is making a dual inlet w/ducts 14" drop base air cleaner for about $100.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: which air cleaner will fit great?
I actually bought a cheap 3" x 14" Summit drop base air cleaner with just about the same set up while including a 1/2" spacer (and the intake is an Air Gap). I did cut the inside area of the hood out around the air cleaner, but it probably wasn't necessary. The air cleaner does have a raised center BTW.
Edit: I didn't notice the IROC hood, that may not give enough clearance.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have a 9 inch Spectre off the shelf from Autozone. It was $30 with rechargable filter (only 2 inches tall). It also had a raised center, but I took a longer bolt, a few washers and a nut, and a 2x4 - I drilled a hole in the 2x4, run the bolt washers through the wood and the filter, and gently tightened the nut until the raised center top became flat instead. Makes a great fit under an IROC hood! 14in jobs tough at least one plug wire on the dist, and the drop-based need that stupid 1/2 in plastic spacer that always leaks and ends up breaking. And with the drop-base, you end up with less airflow since they drop so far that the end result is only about 1/2 inch of available room above the air horn for the air to get into the carb through.
Pic here 1st post page 2:
https://www.thirdgen.org/forums/auto...er-hood-2.html
86IROC112
09-07-2015 01:37 PM
86IROC112
08-17-2015 02:00 PM
