thunder series 800 cfm
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: thunder series 800 cfm
I installed one on a customer's big block a couple years back, spent awhile getting the calibration correct, but it's still on the car and working great!!!! Way too much carb for a small block unless you're running some huge heads and a big, solid roller cam!!!!
well according to holleys calculator i should be running a 950 hp carb with the 355 and a roots blower pushing 10 psi
355cid plus 144 cid(blower)= 499cid
499cid x 6300 rpm / 3456 =909. and some change............. so i was womdering on the perfoemance of the avs 800 edelbrock......
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
with that kinda beast, i wouldnt consider anything less then a holley 850 dp! nice setup dude!!
Hotrodboba400
12-10-2019 07:07 PM
sreZ28
10-22-2015 08:21 AM
Dragonsys
09-25-2015 03:51 PM
