gulp valve
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
gulp valve
my holley 6210 quadrajet model has a fitting at the back of the carb that is plugged but it is called a gulp valve. i believe it's a vacuum source. can i use this for my power brake hose. my edelbock manifold location is blocked by the secondary mechanical pump.
Car: 89 IROC Z28
Re: gulp valve
thanks, so this is full vacuum, do you know why was it installed in the first place and called a gulp valve.
355tpipickup
09-13-2015 11:35 PM
