Carburator/distributor question
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
Well ive been reading up that if you change your carburator you will also have to change your distributor to an aftermarket one. Ive seen many people on this forums talk about it. Well i need help choosing the correct ignition/distributor. Or is it necessary to get one. Im just confused on whether if it needs to be replaced and what with.
My current setup is a edelbrock 3701 intake manifold with a edelbrock 1406 carburator. Can anyone suggest a good/somewhat cheap distributor to go with it. Any response would be very well appreciated.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Re: Carburator/distributor question
And they sell those Procomp ones with clear distributor caps, I got one of those and it looks so cool
Car: '86 IROC
I've got one of these http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Looks identical to a MSD Street Fire I think. I was running with the ECU still hooked up and the original distributer in place before, but all of the injection side of things removed. It was running like crap but it had other problems too so I'm not sure what was down to the distributor. So you can get away with it but I would just fit a HEI distributor with mechanical and vacuum advance, they're cheap and you can get rid of the ECU.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You're cheapest option would be to find a good used GM HEI distributor. I can pull them from junkyards for $10 and with about $10 in parts from Ebay you can rebuild it to like new. I did that for my 350 swap and it's been running great for me.
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Car: 82 firebird
ty for all the responses ill probably pick one up from pepboys or somewhere local so i can get my car running finally.
1991, 305, 88, advance, body, camaro, carborated, carburator, carburetor, check, current, distributor, hei, motor, put, tpi, vacuum
