Canadian q-jet
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: abandoned electronic carb inputs and performance
Are you sure it's not the Canadian model with the two wire connector on top for the fuel enrichment solenoid? The ccc will have a three wire connector to the TPS front/drivers side in addition to the two wire connector on top.
1 Post
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
i dont mean to steal this thread but i need help lol.
can i put an edelbrock carb on this and just not use that plug? and do i need to change my distributer?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Let's give this its own thread instead of highjacking someone else's.
Why do you want to replace the q-jet? You don't need to replace the distributor when you already have a non-computer q-jet, but it won't bolt to a stock intake manifold without an adapter.
No matter how you slice it, a Performer is a downgrade from a q-jet.
1 Post
Re: Canadian q-jet
hey thanks for moving this for me.
heres the story:
installed a edelbrock performer intake and was going to use the edelbrock performer carb. but then i read about the computer control issue.
so can i use the edelbrock carb and just not plug that in and still have the car run and pass emisions?
or should i just clean the crap out of my old one or buy a remand carb.
i dont see how using this stock carb would be better than an aftermarket.
heres the story:
1 Post
Car: 87 Camaro
Re: Canadian q-jet
Q-jets are very versatile and adjustable carbs IF you know how to adjust them. I doubt you'd pass emissions with a non-stock carb, though I could be wrong. I'm sure someone with a little more knowledge will chime in and let you know!
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
