Gas Line Help 82 Camaro
1 Post
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
Hi guys, I have 82 camaro that has 2 gas lines can I hook both lines up to a Y and come out to 1 gas line and run it to the fuel pump. If both lines are open they will leak gas. So I'm thinking I could tie both together in to 1 and run it to the fuel pump.
I'm running a 327 small block.
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: Gas Line Help 82 Camaro
1 Post
Car: 82 Camaro
Axle/Gears: 373
I no 1 is a supply and 1 is a return, what I'm asking is can they both tide together and run it from the gas tank to the fuel pump,2nd? - also do the return gas line need to be hook up. On a carb motor. When both lines was cut the return and supply gas lines they both leak gas.
Car: 89 RS
1 Post
Car: 82 Camaro
Axle/Gears: 373
Well if you hook the return into a supply line then it wont do any good. You do not have to have a return line. But it is nice to save some gas. I am just wondering if your car has an adjustable regulator? If not then you should need one. Maybe someone else would know for sure. Its been done, but not by me. Seems like it would run rich with no return line.
![Name: betlspulleyinstall061.jpg
Size: 56.3 KB](https://www.thirdgen.org/forums/attachments/carburetors/428257d1501499828-gas-line-help-82-betlspulleyinstall061.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
What yr engine?
Look up a fuel pum pfor a 70s to mid 80s full size car with AC, they will have the fuel pump with a built in return line.
You can then use both lines as intended.
Only the big cars with AC had a FP with a return.
1 Post
Car: 82 Camaro
Axle/Gears: 373
I thought the return fuel line was for fuel injected motor. Motor is running with the fuel line, on the driver side running under the frame of the motor to the fuel pump for now just to get it running. The return line is near the exhaust on the driver side to.
The return line is cap off for now had to use a long screw about 1.5" and a clamp to get it to stop leaking. So I was thinking, I can just tie both lines together at the gas tank in to 1 gas line and run it up to the fuel pump. Would this still work and be OK to use it like this.
I have new summit fuel pump. "O" can I use a copper AC line for a fuel line I have about 200 feet roll of 3/8 line it would save from going out to buy new lines to run from the gas tank.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
From the extra under hood heat big cars with carb n AC had a return line to stop vapor lock. Where it get so hot under to hood the gas in the line boils.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
3rd gen cars all had the return line. The stock V8 carb'd fuel pump had a return line.
The stock 3/8" supply line will handle most any streetable engine combination you could imagine. You're better off running the lines as designed than trying to tie them together because you'll benefit more from the return capability than you would from additional supply capability.
1 Post
Car: 82 Camaro
Axle/Gears: 373
With the return line hook up will I lose gas pressure going to the carb.
I can run the return line at the back of the carb gas line.
![Name: 327motorparts038.jpg
Size: 60.7 KB](https://www.thirdgen.org/forums/attachments/carburetors/428148d1501499606-gas-line-help-82-327motorparts038.jpg)
Engine: LS1/LQ4
The return has to be regulated to maintain inlet pressure. You could do that with a relief valve off of the back of the carb line.
AkDrifted
08-17-2015 07:45 PM
92camaroJoe
08-13-2015 06:07 AM
