Mechanical Fuel Pump pull through electric intank pump?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
Has anyone tried using a mechanical pump and leave the electric pump in the tank? I swapped in a carb'd 350 in a 92 rs with a 3.1L and the carb setup is kind of temporary until I get my lt1 intake finished. Will the mechanical pump be able to pull fuel through the intank pump?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Mechanical Fuel Pump pull through electric intank pump?
Don't think so - never heard of anyone even being able to pull through the intank pump with an external electric pump. Why not just use a block off plate where the mechanical pump is, and use the in-tank pump and get the Mallory 4309 regulator?
Car: 1992 RS
Engine: Carbed 350
Your other option is to drop the gas tank, and replace the intank pump with a pick up from a carb car, or some just run a hose in place of the stock pump. But $80 is much easier than dropping the tank in my world, I've done 2 tank drops and they aren't hard, but time consuming.
Car: 82 Z28
Transmission: BW T-10
My '85 will, but I had to hook up a mityvac to the fuel line & build up some suction. Once I did that, it was fine.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Some have gotten away with it, but if you plan on making any kind of decent power, or plan on racing the car, forget it.
I only vaguely recall one person doing it, but if you use a stock factory type return mechanical pump, you should be able to use the in-tank electric as a pusher pump. If needed, you could put an inexpensive ($25 Holley) dead-head reg in line with the carb inlet line.
There are some risks worth taking, and some costs worth avoiding, but trying to pull through a non-operating in-tank electric isn't either one of them.
Engine: 355
Transmission: TH350
just updating this thread for someone else searching in the future. The car does run fine with the mechanical pump pulling through the electric pump. The electric pump is not powered(at the moment). I ordered a holley bypass regulator yesterday, so I will eventually run the stock pump(v6) and remove the mechanical. My plans are to step up to a 255lph pump in the future, but for now I think it is more than enough.
Car: 1991
Transmission: 700
Wow I doubt it was that much money. I have a '91 RS that I am currently putting in a carbed 350. I left the fuel pump and just bought a Mallory regulator for cheap. They don't cost much. Then I ordered a fuel pump block off plate from Jegs for cheap as well.
1 Post
Car: 87 Camaro
How did you cut the power to the fuel pump? I'm doing the same thing you are except my electric pump is still on lol but it still runs fine but I would like to know how to shut it off.
Engine: 355
Transmission: TH350
well cheap is relative, right? The Holley bypass regulator was $68 from Jegs. If you don't need it and there is a way you can do it without spending more money, why buy the regulator? In my case I wanted to get the car running and driving until I get my lt1 intake finished, so I did not want to spend the money on a temporary situation.
Engine: 355
Transmission: TH350
If your electric pump is running, I would imagine it is not good for it. It is essentially dead heading into your mechanical pump. I am actually suprised it is not forcing to much fuel pressure into the carb.
1 Post
Car: 87 Camaro
Well for some reason theres 2 lines on the car but both push gas when I turn the key on and one is coming from the mechanical pump so idk whats up with that. Anyone wanna explain that one?
Engine: 355
Transmission: TH350
the larger line is the supply and the smaller is the return. Cap off the return with a hose and a bolt or something and run the supply to your mechanical pump. Make sure you have the right orientation of lines on your mechanical pump
i just purchased a 92 firebird and dropped a 350 into it, im gonna go the in tank fuel pump with a regulator to the carb, how do you go around the relay for the fuel pump without having the ecm at all? (i read somewhere that without the ecm, the fuel pump will not power at all)
Engine: 355
Transmission: TH350
Engine: LS1/LQ4
The ECM grounds the fuel pump relay to turn the fuel pump on. So, if you do a switch, you need to ground the magnet circuit, not provide power to it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Took some trial n error to get it figured out.
Car: 1992 RS
Engine: Carbed 350
The ECM is not needed to run the fuel pump - it's only needed to prime it. The Oil Pressure Sending Unit runs the pump in a constant state as long as it senses oil pressure. Yank the ECM out - the pump will function fine as soon as the OPSU picks up on the oil pressure created when you crank the car. Before that occurs, you have plenty of fuel in the carb bowls to start the car.
I switched to carb on my 1992 - and it runs just fine without the ECM - I added nothing and wired in nothing. The only issue is if I don't start the car for like a month - then the fuel in the bowls evaporates and it takes a few cranks to get the pressure built up for the OPSU to run the pump and start the car.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
How much of a restriction is the in tank pump while doing this though?
I have a 86 camaro that had a 4.3 v6 tune port injection system now it has a 350 with 4 Barrel carb and it will run for a few mins then dies it has Manual pump on the side of 350 and intank pump too could this be my Problem
theshackle
03-05-2017 06:37 PM
R3500
08-17-2015 12:16 PM
