Carb
Car: 1986 P. Firebird T/A
Engine: Stock v8 305 TPI
Axle/Gears: N/A
Carb
Hey guys, I just bought an 1987 Camaro and I believe the old carb blew and they put on an Edlebroc carv, the fuel line hasn't been reatached and the throttle hasn't either.
Reason I'm posting is because I'm not sure if there is anything else that needs to be done before reattaching those lines and adding the element.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What distributor?
If the transmission is a TH700, you'll want to put a "geometry corrector" bracket on the throttle arm for the TV cable. Just hooking it up to the bottom of the throttle arm isn't good enough.
Axle/Gears: N/A
Re: Carb
Crap, I have no idea what Tranny it is, I have the vin if that woudl help, rest of the car is suppose to be stock.
I honestly have no idea and have no way of checking right now, when I have the chance, how can I check what tranny is in the 87 z28
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: Carb
is it 3 or 4 speed automatic transmission?
Engine: LS1/LQ4
The only automatic available beginning in 1984 was the TH700. If it's an '87 and the transmission is stock, it's a TH700.
Axle/Gears: N/A
Re: Carb
Ok, thanks, if TH700 is the stock one back in those years, it must be then.
Next question, I do need thise geometry corrector for the edlebrock carb? or is it for a specific model?
Engine: LS1/LQ4
You need one made for Edelbrock carbs. As far as I know, there aren't different brackets for different Edelbrock models (Performer vs. Thunder series, for instance).
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
