Help w/ holly carb demensions
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
was woundering if some could tell me if the 750cfm and the 650cfm Double pumper carbs are the same in demensions. what i mean is if i switch from a 750cfm to a 650cfm carb will my double feed gas line hook right up or will i have to shortin it to line up with the inlet holes. thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Assuming they're both 4150 models. If the 750 is a 4160, you'll have to lengthen the line.
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
Re: Help w/ holly carb demensions
actually its the 4779 750cfm DP..so the inlet for the fuel from one inlet to the other is wider on the 650cfm?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If your 650cfm is a #4777 and the 750cfm is a #4779, then all the external dimentions are identical, as are the fuel line fittings, vacuum hookups, choke parts and throttle/secondary linkages.
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
ok..cool thanks man..the 4777 model is the one i was looking at picking up.
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
4777, 57, auto, car, carb, carbueator, carburator, carburetor, demensions, duble, holley, holly, linkage, motor, tpi
