Will this work?
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
Will this work?
Will this Intake manifold work with a quadra-jet?
http://www.edelbrock.com/media/news/...e/img/2701.jpg
Re: Will this work?
No. That works only with squarebore carbs like Holleys and Edelbrocks. You need a Performer or Performer RPM QJet (in the Edlebrock product line).
Engine: L69
Axle/Gears: 2.73's
Re: Will this work?
Car: 85 Camaro Z-28
Axle/Gears: ?
Re: Will this work?
The second one will. If you look at the mounting surface on the intake you can see that it has dual bolt patterns to fit spread bore or square bore. The only catch with that intake is it has the port for the choke. Can't recall if it is hot air or what but some edelbrock's use that port. With a q-jet you'll need a block off plate. My intake came with the plate. You might want to call and double check that that one does as well.
Terrell351
06-13-2021 01:13 PM
