Holley installed
Car: 1986 Z28
Engine: 305 for Now
Holley installed
Well I finally got the holley on my car. And got it running. I think the timing is off a little. Go to give it gas and it stumbles then back fires. Also my distributor is making a clicking sound. Gets louder as the rpms go up . Any ideas is it bad?
Car: 1986 Z28
Engine: 305 for Now
Re: Holley installed
600 vacuum secondaries. I think I just need to tweak it in alittle more. Just dont have time wife works nights have to take care of little ones.
Car: 1983 Chevy Z28 Camaro
Engine: SBC 350
Axle/Gears: unsure
I having a similar problem as yours with my 750. I think my choke sticks sometimes plus I need to tinker with it some more to get it dialed in all the way
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The distributor "clicking" is not normal. Is it a buzzing, perhaps? Check for the cap & rotor properly installed. And, make sure the coil is properly grounded (this is a large cap with coil-in-cap HEI, right?).
Where did you set the timing? 8-12 initial at idle, no vacuum advance hooked up when setting, is a good starting place.
Car: 1986 Z28
Engine: 305 for Now
No its a clicking like something is hitting. Yes its an hei cap. I have to get a timing light. Was just turning the distributor till it ran half way decent.
86IROC112
08-17-2015 02:00 PM
