E-85 question
Old 11-21-2008 | 08:08 PM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
E-85 question
ok i have a 1050 cfm dominator carb i want to try to run some e-85 in it to see how it runs heres what the carb has in it 50cc pumps front and back .040 squrters and 83 jets I am just wanting to know what size jets i should try to go up to and what size squrters i should go up to to run E-85
i know there is tons of threads on e-85 but i just want a simple answer
thanks Eric
Old 11-22-2008 | 06:22 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Find the diameter of the 83 jets. Multiply that by 1.47. Find out what jet that corresponds to. According to my research, that's a 95.
Ditto the squirters. .040" times 1.47, get that size squirters. Idle feed restrictors, up by 1.47.
No power valves, I assume.
Emulsion bleeds: If you have screw-in orifi (I have no clue if Dominators do), you'll have to change those. The 4150 Holley metering blocks for E85 use .028, blank (no hole), .028, blank, top to bottom. I'm not sure how that would work on a Dominator.
Old 11-23-2008 | 12:33 AM
transam360's Avatar
Re: E-85 question
Idle feed restrictors not to sound dumb but what is that i prob know what it is but not sure
nevermind looked them up on summit i knew what they were sorry
according to the math i need a 58 suqirter but all summit has is 50s and 70s what one should i get
according to the math above and 83 jet is .097 x 1.47 = .142 and the jet size is 142 alcohol jet is this right not sure if i did it right
Old 11-23-2008 | 01:16 AM
five7kid's Avatar
Engine: LS1/LQ4
Actually, I didn't state that very well. You need the diameter so you can get the flow area of the jets/squirters/restricters.
So, more like a .048-.049 squirter.
I got the jet size from an Excel file I made that used the diameter to get the flow area, then multiplied that by 1.47, calculated that diameter, and matched up what jet that was. So, that is still correct.
MustangBeater20
10-29-2022 10:20 PM
fasteddi
09-10-2015 10:32 AM
Bubbajones_ya
08-31-2015 01:02 PM
ezobens
08-19-2015 11:29 PM
redmaroz
08-17-2015 12:40 AM
