H/C setup for lg4?
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: H/C setup for lg4?
An LG4 is a 305, correct? If so, head choices are kinda limited. I was going to get the factory TPI corvette aluminum heads for mine back in the day and do some porting to them. Those, and the world products torquer S/R's are about your only choices. A cam with about .470-.480 lift will prob be good for that set up too.
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
honestly your stock heads are better than you probably think!
with just a cam similar to the one above, stock heads and a little tuning you'd
have more than ample power for pretty much anything
sorry been a long day i thought i saw lq4
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The stock heads are fine. A little port clean-up, 1.94" intake valves, cut the guides for positive-type stem seals, screw-in studs, new springs, good to go.
Cam will require higher stall converter if auto. A Comp XE268 or XE274 (assuming flat tappet) would match the RPM intake well.
If it is '84-earlier, it will have dished pistons and low compression. Not a good match for performance. If that's the case, stick to no bigger than the XE268.
Car: 2000 BMW M5
I have used positive OEM type fel pro valve stem seals on 081/416 305 heads without cutting the guides, and with 0.480" lift, no clearance problems. If you make sure the positive seal is seated all the way there was more than enough seal to retainer clearance.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Take it from me, going H & C on a stock LG4 is a waste of time, even with every bolt on part. Better off going to a 350 roller motor where the larger bore will allow better heads to breathe.
Engine: LS1/LQ4
I wouldn't go that far. As long as you don't get any deeper into the engine than heads & cam, and support them with upgraded exhaust, you'll go faster for the same money than you will with a 350. After all, if you get a 350, you'll still have to do heads, cam, and exhaust.
ohoneWS6, exactly what do you mean by the engine being "fairly fresh"?
Car: 1986 Trans am
Engine: 5.3 LM7
I used to hand it to L98 cars all day with my old 305. Miss that engine sometimes, haha. I used a Comp cams .464, .470 lift FI cam. Don't know the part number, but with my stock heads, headers and exhaust I made 220RWHP, and 280 torque. Throw a set of heads on that and your prob around 260 RWHP, and I could have gone a little bigger with a cam, so when it's all said and done, you could probably make almost 300 to the wheels if you choose your set up right.
LT1Formula
10-08-2015 08:34 PM
