View Poll Results: Which Carb
Holley Classic Carb Double Pumper 650
100.00%
Road Demon 725 Dual Line
0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Which carb for my 350 sbc.
Car: 1985 Camaro Sport Coupe
Engine: Twin Turbo crate 350
Transmission: TH350
Axle/Gears: still workin on that
Heres the problem I had a v6 85 Camaro and I'm getting ready to put in my new 350.
The guy I bought it from said that the Holley 670 Street Avenger was the way to go, but I heard someone else say that's not big enough for a stall over 1500 rpms. Well I have a 2200 - 2400 stall. Heres everything about the engine and under it I'll tell you the tranny and rear end.
- 3.484" stroke nodular iron crank
- 5.7" forged rods with ARP rod bolts
- 9 to 1 compression flat top pistons
- Seasoned 4-bolt main block
- Deck head gasket surface on block to ensure a good seal
- New CompCams hydraulic flat tappet high performance cam-NEW INFO-------Lift: .470''-------Duration: 270°
- 76cc heads with 1.940"Int/1.500"Exh valves
- New 1.250" high performance springs set up to match cam
- New High temperature valve seals
- New Spiral-type valve guides
- New Screw-in rocker studs with guide plates
- New Steel rocker arms with ***** and nuts
- New Hardened push rods
- New Perfect Circle rings
- New Double row timing set
- New High volume oil pump with welded big pickup screen and steel drive shaft and steel guide
- New Revolutionary 1-pc design molded rubber oil pan gasket with load limiters to prevent over-tightening and higher temperature resistance than standard cork-rubber gaskets
- New Brass expansion plugs
- New Edelbrock (non-egr) Dual Plane Performer aluminum intake
- All parts are painted separately before assembly for that show quality look
- Edelbrock (non-egr) Dual Plane Performer aluminum intake manifold.
Car: 87 irocz
Engine: 436 chevy sbc
Transmission: th 400
Axle/Gears: 373
Re: Which carb for my 350 sbc.
was is the lift on the comp cam that will make a big difference what carb will work best.also what is the duration on cam.
Transmission: TH350
ill get that info on here as soon as i can i just emailed the shop that built it for a part number
Transmission: TH350
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
882's are the last three digits of the casting number on the heads, 76cc heads are normally what is refered to as smogger junk or wheel chocks. 882 castings are a prime example.
As far as carb recommendation I think you'd be quite happy with a Holley 650 dp, some people may recommend a 750, but in my opinion it's a trade off, a 650 would most likely provide the best throttle responce.
Transmission: TH350
so in other words my heads arent any good
I was generalizing, find out what the casting number of the heads are and find out what they actually are (casting numbers are located under the valve cover and are typically 7 or 8 digits). Chances are they arn't anything great but that really doesn't matter at this point. Heads are changeable in the future if you ever decide to upgrade. It sounds like a basic rebuilt 350 which is a decent starting point for a reliable street car. Get yourself a carb, get it running and go from there. Also keep in mind the hp and torque ratings are most likely at the flywheel, the actual output at the rear wheels will be a good deal lower when you take into account losses from drivetrain, exhaust, and accessories. 10% to 15% loss is cosidered normal.
Transmission: TH350
Transmission: TH350
NEW INFO
the heads are 369's
the heads are 369's
1 Post
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
A 670 will probably be too big. You'll be better off with a 600 cfm or 650 at max.
Transmission: TH350
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
A Holley 670 CFM is a Street Avenger vacuum secondary carb. I would not recommend it.
The heads are costing you 20-30 HP vs. what Vortecs would produce. A 670 Street Avenger would be .1 to .2 seconds slower in the quarter mile vs. a 650 double pumper.
Engine: LS1/LQ4
That's failsafe advice to keep people who think "bigger is always better" from ruining your reputation.
There's nothing wrong with a properly sized double pumper on an automatic car. It took me awhile, but I finally learned that lesson in 2003 - 750 VS to 650 DP gained .2 sec in the quarter. Going to 750 DP gained another tenth.
Listen to that man, he knows what he's talking about.
Transmission: TH350
So should I go with the Holley Classic 650 Double Pumper? Im also looking at the Road Demon 725 Dual Line carb. What do you think check out my poll. Why or why not should I use one or the other?
Holley
http://www.jegs.com/p/Holley/746470/10002/-1
Road Demon
http://www.jegs.com/i/Barry+Grant/13...0VE-R/10002/-1
Holley
Road Demon
Engine: LS1/LQ4
The Road Demon is vacuum secondary. Quality problems with Demons seem to be pretty common these days.
The classic DP would be fine. A 750 wouldn't be too big, especially if you get better heads some day.
1 Post
Car: 1991 Camaro RS
Engine: 355
I just bought a Quick Fuel 650DP, its a great carb. I bought it used (less than a year old).
Transmission: TH350
theshackle
03-05-2017 06:37 PM
Eric-86sc
08-24-2015 09:01 PM
