Which carb for my 355?
Old 10-18-2008, 10:05 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
Which carb should i get. Here are engine specs:
vortec 355
062 vortec heads
edelbrock rpm air gap intake manifold for vortec heads
comp cams grind cc306
510/540 lift. duration@ '.050 230/244
long tubes
Old 10-19-2008, 12:35 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Which carb for my 355?
LOL...same question 4 me too.
Sportsman2 heads
.488/.510lift @ 1.5 rocker + 1.6 rockers
234/244 dur
shortys 1 3/4
RPM intake
I got a 750 right now and its nice on the WOT, but really rich on the normal drive and idle.
Old 10-19-2008, 01:11 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
vortec 355
062 vortec heads
long tubes
are the heads stock?
Old 10-19-2008, 05:15 PM
Car: 1985 IROC
Engine: lb9
Axle/Gears: 3.42s
no, they have been midly ported, bowl blended, and cleaned up. stock valve sizes.
Old 10-20-2008, 01:39 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If the valve guides haven't been cut down, you won't have enough valve travel to run that cam.
Old 10-20-2008, 01:47 AM
Car: 1985 IROC
Engine: lb9
Axle/Gears: 3.42s
I'm running comp cam's beehive springs and retainers which grants a little more than .550 lift.
Old 10-20-2008, 04:51 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
If the guide bosses were not cut down then you can have all the spring you want but when the valve opens you'll bottom out the retainer on the top of the valve guide.....which is bad bad bad!
codeysabatini
11-10-2015 04:07 PM
2012sergen11
10-13-2015 07:38 PM
Damon
09-26-2015 04:29 PM
BLK87Z
09-18-2015 11:29 PM
Billy Decker
09-04-2015 03:46 PM
Quick Reply: Which carb for my 355?
