Fuel leak Holley 650 dp sendary float screw
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I started my car for the first time in a couple months today, I noticed I have fuel coming up from the float adjustment screw on my secondary fuel bowl, is this as simple as the float level being set too high or do I have bigger problems? I rebuilt the carb about a year ago or so and I thought I had the float level set properly.. I guess I'll pull it apart and take a look, just looking for some suggestions, is there anything else it could be? I had it running quite a bit since I rebuilt it, this is the first time it's leaked..
Re: Fuel leak Holley 650 dp sendary float screw
Float was stuck. Can't say I recall a gasket being under it honestly.. problem fixed.
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
there is a little foam or rubber gasket that looks like a washer inder the adjuster they can tear easy is the spin the screw and the seal is not lubed up good
9192camaro
16
02-03-2019 12:21 AM
86IROC112
08-17-2015 02:00 PM
