help me make my edelbrock 1411 work right
Old 07-04-2008 | 08:31 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
I am rebuilding an edelbrock 1411 right now and have no clue what jets/etc i need to run in order to have a good baseline for performance.
The carb may be less than ideal for my setup, but it was free and i figure ill give it a shot..
My setup:
327ci motor, with L69 heads, hooker comp headers, summit's basic idle-5500rpm cam, edelbrock performer intake, 700r4, 3.23 gears in a 1984 trans am. If there is any other info I am missing let me know. I do not have the 1489 tuning kit for this carb, though i can pick one up if needed. I do have the 1479 tuning kit already.
Thank you greatly for any help. I have never had luck with tuning carbs and would like to get this one set up properly to start things out.
Old 07-04-2008 | 08:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: help me make my edelbrock 1411 work right
Pretty much everything is covered in the Edelbrock manual.
http://www.edelbrock.com/automotive_...411_manual.pdf
Old 07-04-2008 | 09:18 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
It isnt me being lazy, but that is all ridiculously hard for me to follow
.. i just cant grasp what all it is saying.. I was just kind of hoping for a "put this part in and it will run" solution.... then i can go trial and error from there.. is there a baseline part that i can put in and at least have it run?
thanks!
edit.. the current jets and metering rods are corroded and all around funky....otherwise id leave them in.
Old 07-04-2008 | 09:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The parts you already have are the "baseline", it'll run with pretty much whatever's in there.
The manual might seem like a lot, but it doesn't get much simpler than that. You're not going to have much luck tuning it without understanding everything in there.
How are they "corroded"? Do they have a little dull brownish coating? or are they covered in green "fur"? Whenever you get a used carb you generally have to assume it needs to be rebuilt.
Old 07-04-2008 | 09:48 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
a little bit of green on them...
Thanks for the info.. i was thinking
that if i didnt get it within a couple of thousandths that it wouldnt run at all.. if It will run then i will have no problem just swapping parts and seeing which works best. Thanks much! Questions answered!
theshackle
09-17-2020 09:26 AM
Reddeath210
10-06-2015 09:20 AM
86IROC112
08-17-2015 03:00 PM
89-S-dime
08-12-2015 12:57 PM
matthew911
08-12-2015 10:38 AM
Quick Reply: help me make my edelbrock 1411 work right
