Whats the best way to remove holley choke horn
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
What is the best way to remove holley choke horn?
What do I need to know?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Whats the best way to remove holley choke horn
well u can just cut it off with a grinder and clean it all up good with a die grinder, but y are u taking it off. its not going to effect your flow enough on ur 305 to notice, and it sure is nice having a choke on a street car...
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed... best way is to replace it with a purpose-built chokeless main body.
That said, I removed the one on my 4777 with a cut-off wheel on a die grinder to 'rough it out' then a grinding bit to clean it up and smooth out the edges. Worked well. You'll really want to blow it out with compressed air, dip it in carb cleaner for a night, and blow it out again after though... there will be lots of metal shavings.
Its a holley 750 dp
Its not for street use, I have never used the choke.
I have never used a choke on a street car either. This is in SC.
Its on a race only 350
I was thinking about using a drimnel tool with cut off wheels and a hand file.
What is the main benefit of this mod?
Car: 1991 Z28 1LE
Transmission: 4l60e
a lil more air flow ...best way really is how five7kid said, and on a side note im in texas and a choke comes in hady hear....but thats another thread...i see its not for a street carso thats moot....so if u do cut it off just make sure u clean it real well like adam sugested i left it off b4 cause i figured u would know that....
Can removing it hurt performance in any way?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
It can make it harder to start cold.. what is your reason for wanting to do this?
Car: 1991 Z28 1LE
Transmission: 4l60e
no it shouldnt hurt performance any just the start up that u said u werent concerned with anyways
1 Post
Only reason I did it was for clearance issues... it fit OK with a drop base air cleaner under the hood with a 3" filter, but after checking closer, the top of the choke horn was about 1/8" away from the lid, which I would think would be a HUGE resitiction. I have yet to use the carb though.
I think I found a way around the cold start problem though... at least for the 4150/4160 Holleys anyway. I bought an A/C kicker solenoid and bracket from Holley (used to bump open the throttle to up the idle speed when the A/C is turned on). It can kick the throttle open quite far though, and is totally adjustable, so put that on a switch and use it to keep it idling fast enough to run decently untill its a little warm, then turn it off to let it idle normally.
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Would having a chokeless carb effect gas milage any?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You'd probably waste more fuel pumping the accelerator trying to keep a not-warmed engine running than you would with a properly operating choke.
I cut it off with a dremnal tool.
Then went to sanding drums and smooth stones.
I was much easier than I anticipated.
Car: '91 Firebird
Engine: 305 TBI
I thought I read somewhere that cutting the choke off will mess up the flow to the air bleeds or something like that. I think they said you have to adjust the air bleeds after cutting it. I don't know... I do know that I've seen lots of people do it before and I just barely heard about the "air bleed" thing.
86CamaroDan
09-29-2015 10:08 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
