Tool's for rebuild?
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Tool's for rebuild?
Gonna attempt to rebuild my carb this weekand on my own, is there any special tool I should get to make the job easier or will just common tool's do the job?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Tool's for rebuild?
Stock q-jet right?
Make sure you have the torx bits. T8 and T15 and T20 to be specific.
Make sure you have a small flat blade screwdriver bit, like eyeglass repair size.
You'll need a small allen key, maybe 1/8" or so. The last two I mentioned there are for adjusting the air valve tension.
Grab the "carburetor adjusting tool" from Napa, $11 or so. You'll use the "double D" bit on that for adjusting your idle mixture (if it's a non-cc model, probably won't need it if it's a CC model).
carb dip, can of compressed air... Maybe digital calipers to measure your power piston height....
Wide flat blade screwdriver, to remove the jets. Gotta be the widest one you have.
A 1/8" pin punch is handy for removing the acc pump linkage, although I rigged up a bent nail to do the trick...
Car: 2000 SS, M6
Engine: Modified LS1
Awww, you got it all wrong! You forgot the most important tool:
Beer!
Don't forget extra gaskets, and hoses. You might end up splitting hoses
during removal.
Beer!
during removal.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Pretty much standard tools - 1" combo wrench and feeler gage is about as complicated as it gets.
Ditto the dip-type carb cleaner & compressed air. If you don't have access to an air compressor, the spray can carb cleaner with the nozzle tube can be used to blow out passages after soaking.
Car: 1982 Trans-Am
OH! Then forget everything I wrote.
