quadrajet secondary help
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
my carb is missing all the vacuum stuff and linkage for the secondarys , my question is can i get ANY q-jet and use it for the parts? or does it have to be the same one i have? all i know about it is, its from a 1977 chevy with a auto trans, non cc. also what goes in the hole on the manifold where the aluminum patch is?
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: quadrajet secondary help
It appears that the choke and everything attatched to it are gone. You should be able to get the parts needed from a carb of similar style IIRC, or you might consider a reman or something as there are alot of missing parts. The block off plate is covering the EGR ports on that manifold.
ok thanks , i will probably just get a junkyard carb because i dont have extra the money for a reman. carb. the car runs good (could be better)as-is so if i cant fix it i will just save for a reman.
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
i dont know it was like that when i got it, im trying to sort out all of the half a$$ jobs done on it .
gta892000
09-16-2015 12:37 AM
