Holley 670cfm Street Avenger
Car: 1985 Camaro Z28
Engine: 350ci SBC
Transmission: THM-700R4
Axle/Gears: Stock
Ok, so my daily project is almost done. before this, the only carb's ive dealt with are Edelbrock's and Quadrajet's so i need some help, having never fiddled with a Holley before. I need to know what to do with the tube on the other side of the carburetor opposite the fuel line.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Well, I suppose you could do pretty much whatever you want with it.
Put old chewing gum in there, for instance.
Most people don't do anything with it, because it doesn't do anything. Both primary and secondary fuel bowls are made from the same casting, then in final machining they become either a primary or secondary fuel bowl. Or secondary double pumper or secondary VS.
Car: 2000 SS, M6
Engine: Modified LS1
Re: Holley 670cfm Street Avenger
That side should be pluuged from the factory. Are you saying it's open and
fuel is able to run out?
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
