edelbrock running rich
Car: 85 camaro
Axle/Gears: 342
i have a basic 350 with about 9.5 to 1 comp, edelbrock performer cam and intake, camel hump heads 1,94/1.5 valves, and i just got this thing running and it seems to run great, i set the idle to about 750 in park and adjusted the a/f screws with a vacuum gauge to get the most vacuum and set the timing to between 8 and 10* with the advance disconnected, and it has great response and very clean rev with no black smoke anywhere, the problem is i pulled a few plugs and their very dark black and sooty, what would be the first step in correcting this problem? its a performer series 750 carb btw
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: edelbrock running rich
Trying to fine tune the a/f ratio with plug reads is going to be pretty tough, thats more a ball-park method. If you're looking to really dail things in, you can consider a wide band O2 sensor and spend some time dialing things in. Plug reading needs to be done with a fresh plug, if you've given it a decent amount of time to idling before doing the read, you're not going to know if it was the idle, or the power stage that darkend the plug. You can keep dropping jet sizes until you start to lose power if your rich other than at idle, you'll find a sweet setting if you play around long enough. It sounds like you followed procedure for the "lean-best idle" that Edlebrock has outlined. So, just keep playing with the power stages if you think its rich. Just remember, only one change at a time, or you won't know what help/hurt from the last combination.
Car: 85 camaro
Axle/Gears: 342
i havent actuall driven the car yet, just started it and broke the cam in, and let it warm up a few other times, seems to run fine, and i pulled one of the plugs just for the heck of it to see what color it was and it was very black and sooty, so should i start with changing the rods? thats what i was told by a guy i know???
1 Post
Car: 1986 Camaro SC
TWON_3rdGEN (01-02-2020)
86IROC112
08-17-2015 02:00 PM
