02 sensor
Car: 1987 Camaro
Engine: 5.7
02 sensor
Im looking at doing a tuneup on my car. Ive heard some 02 sensors are better than others with the ccc q-jet and better mileage and performance. I was wondering what brand I should use?
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
Re: 02 sensor
Bosch makes a good product,Summit racing now sells Stock replacemet parts for everyday rides,you cant go wrong with Summit,they have a good Tech department also,you should need a 1 wire 02 sensor.
Car: 1987 Camaro
Engine: 5.7
Re: 02 sensor
Ive also heard they make good products and thats the kind I currently have, but i heard that they arent good for our cars thats why I was asking if there is a better alternative? same with there spark plugs.It is a one wire.
Re: 02 sensor
Ive used Bosch for years in the Fbodys,never had a problem,you may be thinking of a HEATED O2 SENSOR,they are 3 and 4 wire.
Some different brands are,AEM,CATCO,NTK(not NGK)HOLLEY,COMP CAMS,each company makes O2 sensors both ways,HEATED and NON HEATED.
Try one of those companys,but I have bought 1 wire O2 sensors before,and when I pulled them out of the box,they said Bosch ,even when they was from a different company.Bosch is the largest company in the world that sells O2 sensors!!!!
Car: 2000 BMW M5
Re: 02 sensor
I always hear a lot of complaints about the Bosch sensors on these cars. A brand new genuine delco AFS20 sensor cost me $12 on ebay a few weeks ago. I wouldn't use anything other than OE.
Car: 1987 Camaro
Engine: 5.7
Re: 02 sensor
Same with me, thats why I was going to use something different the next time I change it. thanks for the part number too
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
All the heated O2 sensor does is make sure the sensor is up to temp when the coolant reaches 110 degrees and enables closed loop. It would only improve mileage for whatever short time that the coolant is warm enough but the O2 sensor isn't - which probably isn't happening with shorty headers.
I've been running a Bosch O2 sensor, my wife thinks the car exhaust stinks, but I can't smell it (can't smell much, actually). I haven't bothered to see if another brand is available without going to GM.
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: 02 sensor
w/ heated O2 my car is heating up faster on cold days and that's nice
I wondered what temp it was that engine coolant had to be before compuer carb had a signal.
HoosierinWA
10-07-2015 10:15 AM
