Rollover vent?
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Rollover vent?
Hey guys, I just installed a fuel cell in my project car. Its an aluminum rci withthe three ports on top fuel out, return in, and the rollover vent. My question is what do i do with the third vent? Do I just throw a filter on it? route it out of the car with a rollover valve? Couldnt find anything in search. Thanks
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Rollover vent?
sounds like you have the same fuel cell i do. anyway yea you run it outside of the car away from any heat/spark source. it should already have a little check ball/roll-over vavle inside the fitting. if you turn the cell upside down you should see the ball come to the top of the fitting.
Pac J
05-17-2020 10:44 AM
