Holley carb
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Holley carb
After years of searching for another F-body I have finally found what I was looking for...anyway one to the question...its an 86 with a 5 speed, the motor is suppose to be an allen armstrong 350 (he builds some crazy engines) and it has a holly 4BBL double pumper. Problem is I live in a small town here and there isnt a mechanic around here that would touch carb let alone be old enough to even know what one looks like haha. I have very little carb no how other than what i have read in magazine's, so whats a guy to do in the tunning department?? As of now it kinda runs like crap...decent when your crusin but if you stand on it it just starts breaking down but if you ease on the gas its fine but I can't tell if the secondaries are even opening...also is there a number on the carb I can get to tell what cfm it is?? any help would be muchly appreciated.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holly carb
Thanks I'll get the number off it tomorrow...worked late tonight then had to put an alternator on the daily, so I'm done for the night haha
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Holly carb
You're looking for the 4 digit number (sometimes followed by a dash and another number) on the choke horn.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
sorry it took so long but I have those numbers now...
List-4776-2
1587
those where all the numbers I found and in that exact way. thanks for the help guys this forum is so much more helpful than others I've been on.
List-4776-2
1587
1 Post
Re: Holley carb
4776 = 600cfm double pumper, 4150 body style (4160 is vacuum secondary).
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: Holley carb
It's also possible that carb may be too small for the motor. Maybe post up some more specs on your fuel system and motor specs too. Lets see what we can do for you.
I would make sure the jets, squirters and cams are all stock. Tune from there. When you give it gas, make sure you see gas squirting into both the primaries and secondaries. You may also need to check into your fuel delivery; you may need a better fuel pump ect.
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: Holley carb
1 Post
Re: Holley carb
Find out first for certain if its a 305 or 350... a 600cfm would be just right for a 305, and would work nicely on a mildish 350 too. A 750 DP would be too much for any 305, and too much for alot of 350s as well.
When it comes to carbs - when in doubt, go with the smaller one. The smaller one will give better driveability and steet manners.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
I wish I could tell you guys stuff about the motor but unfourtunetly I know nothing about it. I was (told) it was an allen armstrong motor, and around here that is a big bonus, he even builds some race motors that are shipped to him from the state's. As far as specs go I'm thinking it's not much more than 30 bore and a little refresh (the guy told me 300 horse at the crank but I higly doubt it) and maybe (maybe) a little better cam, it doesnt have a lumpy idle tho but it could just be a very mild cam. Im trying to get ahold of the orignal owner so I can get some info on the motor. I spent almost 3 hours cleaning and detailing it and decided to take a better look at the carb....and its filthy inside lots of crap on it. I think over the winter I'll pull it off and give it a cleaning and a rebuild (well not me but you get the idea) then go from there. Also do holly's make any noise? Cause not hearing the (4bbl) noise is what got me wondering. again I really apreciate all the help you guy's are great.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
Engine: 400
Re: Holley carb
Is there an easy way to see the numbers on the back of the block? cause I just spent like 20 mins with my womans compact thing trying to get it down there far enough but still couldn't haha the heater core lines are only a little in the way but there is a bunch of wires in the split loom that are really in the way....any one know some tricks? haha
The key is to remove all the excess stuff, like heat and windshield wiper motors etc (sarcasm). Who needs heat?
As for your previous post. First things first, ID the block. Lets find out if its a 350 or 305. Then pop off the valve covers and get the casting numbers on the heads. We can find out some more about what you've got going on there. That's a good start, granted you still wont know what type of pistons you've got or what cam you're running. If someone told you it's 300 hp, it's probably just a 350 with stock heads and a mild cam. Did you say it had an aftermarket intake? Good luck.
-Greg
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
I didnt say but it does have a wiend (sp?) intake on it, oh and a stupid cold air intake thing of a chevy truck...chrome tube with a filter on it, but no worries Im on the look out for a nice open element cleaner.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
yes it has all new piping front to back (headers are old) and a vortex muffler (some sort of chambered muffler)
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Holley carb
heater core shouldnt be in the way if you're looking for the casting number, the # is on the drivers side, heater core is on the pass side..
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Holley carb
head casting numbers are on both heads... normally between the center rocker arms
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
sweet I actually went out and bought an extendable mirror so I could see the casting on the block and now I can check the haed numbers at the same time. thanks
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
Okay I got all the numbers I could see and I was on that mortec site and none of my numbers are on there? Now the engine one its possible I messed that one up, but the ones on the head I know are right cause I double checked them after I wrote them down...Ill post up the numbers and see if you guys can help me out cause Im lost.
block...3670100, I think the six might be a nine now that i think about it but it still didn't show up.
Heads...64..which I assume is the cc...8782461...then under it B274 and GM6 was in the middle of the head. thats all I can come up with...Im gonna go see if i messed up the block one after my back recovers haha
Engine: 400
Re: Holley carb
I can't seem to find anything on those heads.
B274 would be the date casting. I think that means Feb 2nd 1974.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
Maybe I did mess up on the heads but Im almost positive thats what they are...give me a sec and Ill pull the cover of again...takes like 10 seconds....just has those wing things on it you take off with you hand...I don't really care for them but what can you do
Engine: 400
Re: Holley carb
I'm pretty sure the head casting is "3"782461. According to Mortec that's a camel hump head.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
haha yea there was a bit of oil on the 3 and it looked like an 8 lol oh well at least now I know haha thanks for all the info and help. So if I go looking for parts for this motor what years could I use? or are they pretty much all the same...ie starters,alternators,and belts and stuff like that
Engine: 400
Re: Holley carb
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Holley carb
nothing really rite now but next summer when its outa storage Im gonna put new belts on it and change the oil...just little things like that
Engine: 400
Re: Holley carb
Yeup. Just run some 10W30, and a standard small block oil filter which the parts store will be able to supply you with. As for belts, you may just want to take off the ones that are on there now, take them in and get ones that are the same (size). I would assume they are just v belts.
Engine: 400
Re: Holley carb
That's cool. But I've got to study for some Physics here. Shoot me a PM or an IM if you've got more questions and I'll try to help. Good luck.
sreZ28
10-22-2015 08:21 AM
