Post your Carb times! 1/4's and 1/8ths
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: Post your Carb times! 1/4's and 1/8ths
350 l98 stock cam and heads mods in the signature best time to date 14.031 @ 98.24
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
13.79 @ 101mph in quarter at E-Town.
Consistent 1.90's in 60 foot.
Car: 89 RS
Transmission: th350
13.90 with a mosly stock 305, has small cam, headers, holley street dominator intake, and spare 750dp.
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
92 RS
383, Demon 750, Super Victor intake, AFR 195's, MSD ignition, Hooker Super Comp headers, Comp 286HR cam.
TH350, 3:73's, Eaton posi, 10 bolt rear! with BFG 275/60/15 DR's
11.49@114
1.60 60'
100% Street car that i drive to work (when i don't drive my 2002 SS)
11.49@114
1.60 60'
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Remember when I created the same thread only for TPI? Hardly anyone was in the 13's and only one guy in the 12's.
Almost the same engine and exhaust except carb, and these guys are pulling a full second on the TPI guys. Just some evidence why Carbs are here to stay.
Other reason, is so that the people who have similiar setups and look on here and say, "that is probably, what I will run."
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
385, 10.65:1, brodix racerite 200's, comp 306S, ported vic. jr., 750 annular mighty demon, full msd, hooker super comp's, 275-50-15 mt street radial(spinning like crazy), t-5, 3.89 9"...
best times & mph:
60'-1.810
1/8- 7.855
mph-90.21
1/4-12.317
mph-114.19
hopefully new, better times on friday..
best times & mph:
60'-1.810
1/8- 7.855
mph-90.21
1/4-12.317
mph-114.19
Car: 2000 BMW M5
1991 Camaro RS 4150 650cfm VS on 305 small block from 86 z28 with Holley Street Dominator Manifold, MSD 8361 Pro-Billet Street distributor w/vacuum advance, 6a ignition and blaster 2 coil. Flexalite Low profile puller fan, optima red top, under drive pulley, moroso 8mm blue max wires, and pro comp rocker arms. 700r4 trans 3.42 gears.
I was disappointed in my times, the car can do massive burnouts and holeshots. Feels like there is plenty of power, but it just doesn't seem to be pulling like it should. I was shifting around 4.5k, the motor would start to pop after that. Motor has a little stumble at wot. But i'll post my best run out of 7. Anyone have any advice? Does this sound right?
60' 2.259
330 6.668
1/8 10.309
mph 67.42
1000 13.437
1/4 16.050
mph 86.40
60' 2.259
330 6.668
1/8 10.309
mph 67.42
1000 13.437
1/4 16.050
mph 86.40
Car: 89 RS
Transmission: th350
I had a bone stock tbi 305 in my car that i put a carb on and it ran 15.5s with a sliping trany. Put a new trany and added a 3k 10" converter and it would run consistant 15.0s with a best of a 14.9x.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay how do you manually shift a 700R4... without moddification
then if you are breaking up around 4500rpms there is something wrong
so yes i think those times could be better as you were probably pushing 4500rpms at the end and only accelerated 19 mph from your speed at the 1/8
Car: '82 Z28
1.68 60'
7.56 @ 90.92 1/8th mile
11.87 @ 114.65 1/4 mile
350 .030 over
MSD 6AL box
MSD Blaster 2 coil
MSD Pro Billet dizzy
Mighty Demon 750
Victor Jr intake
Comp Cams 294S solid lifter cam
Pro Magnum RR's
AFR 195 heads
10.5:1 compression
6 inch H-beam rods
Wiseco forged pistons
1 3/4 long tube headers
Dual 3 inch exhaust
4,000 stall Edge Racing converter
TH400 trans
Currie 9 inch running 4.56 gears w/drum brakes
Hoosier 28x9 slicks
Moroso DS2 26 inch front runners
Prostars all around
Spohn relocation brackets
Spohn torque arm
Stock rear sway bar, no front bar
Full interior
Dunno what the car weighs but the front sits a little higher than the rear on stock 25 year old springs. I shift at about 7,000 rpm and cross the line at around 6700 to 6800 rpm.
350 .030 over
MSD 6AL box
MSD Blaster 2 coil
Mighty Demon 750
Victor Jr intake
Pro Magnum RR's
AFR 195 heads
10.5:1 compression
6 inch H-beam rods
Dual 3 inch exhaust
TH400 trans
Hoosier 28x9 slicks
Prostars all around
Spohn torque arm
Full interior
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
86 Trans Am LG4 305, Edelbrock 1406 carb, Edelbrock 7101 intake, stock manifolds, stock y-pipe, flowmaster muffler.
14.943@91.67mph
14.943@91.67mph
![](http://www.transamws6.com/pics/transam/timeslip.jpg)
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
See signature below:
Car: 1984 Trans Am
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Whats your jetting, rods and accelerator pump setting on the 1406 - I'm fine tuning on mine and curious to what others have run. I'm hopeful, if you can run a 14.9, I think between me running a similar combo, but w/ headers and a small cam, a stall and 3.73 rear, I could put down a mid 14. Only one way to find out, maybe in a few weeks.
Carb was bone stock with no adjustments made to it. took it out of the box, put it on the intake and just drove it.
1 Post
Car: 1986 Camaro SC
No kidding. Mine tolerated a lot more fuel than the stock calibration, I ended up with stock primary jets, .73/.42 rods, stock vacuum springs, and .101 secondary jets, with the accelerator pump in the middle hole. I'm gonna run a plug chop for the top end, but I think I'm still lean up there.
I didn't know anything about carbs (still don't really know anything about them now).
The stock quadrajet stopped working (MC Solenoid failed or something) and I was quoted $200+ to rebuild it, so I opted to go with the Edelbrock 1406 since it was only $219 at Advance Auto and the Vacuum advanced dist was $60 I think.
I put those parts in and the car ran like a raped ape. I was pleased.
this video was the day I hit 14.9 (was also my very first time at a drag strip)
unfortunately, no one videotaped that pass.
http://www.youtube.com/watch?v=WfxYUYvUnT8
Car: '82 Z28
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 1984 Trans Am
oh good lord.. thats a huge tire.. what does that bird run?
Car: 83 CAMARO 468BBC
Engine: 9.84 @ 138mph street driven
Transmission: TH 400
Axle/Gears: ford 9" 3.70 gears
Wow what a post I guess you are up for a lot of reading
I guess people love the chance to shout this one out
9.841 @ 138.57 1/4
6.322 @ 112.40 1/8
9.841 @ 138.57 1/4
6.322 @ 112.40 1/8
K ran the car finally! Corrected sea level time is as follows:
14.6 @ 96 mph
Still need to get dyno tuned. But I'm decently happy,
14.6 @ 96 mph
Car: '82 Z28
Last time out with the new engine with only 1 pass on it, 11.17 but forget the mph. A shift linkage broke during the burnout on the 2nd run
3550 lb car, all motor and pulling the front wheels off the ground a good amount.
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
well i haven't put my motor together yet but, what do you guys think it will run?
350 4 bolt
luinati cam 218 dur. 458 lift both sides 110lsa
trick flow 195cc heads 62 cc chambers 2.02, 1.6 valves
Edelbrock Performer RPM Intake
600cfm carter afb carb, very similar to edelbrock 1406
edelbrock tes headers
built 700r4
3.73 posi
k&n 14x3 filter
350 4 bolt
built 700r4
3.73 posi
k&n 14x3 filter
1 Post
Car: 1986 Camaro SC
350 4 bolt
built 700r4
3.73 posi
k&n 14x3 filter
350 4 bolt
built 700r4
3.73 posi
k&n 14x3 filter
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Sounds like a nice streetable combo. Isn't 600cfm a bit small for heads like that? I would think if your going to go vacuum secondary, you might as well go with the 750cfm on a 350 w/ good heads and a mild cam. What kind of tires are you going to run, that is going to make or break your launch. You didn't mention the converter either.
1 Post
Car: 1986 Camaro SC
Converter is going to depend on what you want for the car, but a happy medium would be a 2500-3000rpm stall, will lockup still maintained. With 3.73 gears behind a 700R4's wildly low first, you don't need a ton of converter unless your gonna run aggressive enought tires to stick all that torque in first. I have a 2500 stall w/ 3.73's behind my 305, it works pretty good, I can blow the tires off in first with that little motor, so any more converter would be a waste anyways. Think before you upgrade the converter, you need to strongly consider more than a 600cfm carb. 650 or more with a double pumper, with vacuum secondaries 750cfm would be fine.
Car: 1984 Trans Am
yikes!!! i would love to run our 10.90 class someday.. a 29" slick could be in my distant future plans.. lol
