Holley 600 T.V cable brackets
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Hi im just wondering if somone here knows the part numbers for the T.V cable bracket and adaptor for a Holley 600 (Vac Sec). My Internet is being a pain and keeps crashing or id try find it myself.
Thanks for any help!
Re: Holley 600 T.V cable brackets
Don't worry I got em 20-95 (bracket) and 20-121 (throttle adjuster).
I got a Holley 600 moddel 4160
I already have a throttle cable stud tho, is it in the wrong location?
Why would I need another one?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Just so you can connect the throttle cable in the factory manner.
If you have one, then go ahead and use it.
What dose the factory throttle cable look like coz i think i got an aftermarket one.
mine has a round metal thing on the end of it with a hole that clips over the bulb like throttle stud then a metal sleeve is slid over to hold it there.
Engine: LS1/LQ4
The factory has used that type, but I didn't think on 3rd gens anymore.
Perhaps changed in later years. Mine is like the Holley one I posted, the cable end is a simple flat drilled piece with a clip that goes in the slot at the end of the stud.
orderd but OUTCH!
20-95 = $40.00AUD
20-121 = $38.00AUD
Not cheap for two little bits of metal.
20-95 = $40.00AUD
20-121 = $38.00AUD
Hotrodboba400
12-10-2019 07:07 PM
