K&N stub stack
Old 06-03-2007 | 08:23 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
K&N stub stack
Just installed one on my holley 750VS. I have a summit standard drop base cleaner with a 4" k&n filter in it. The instructions say to have 1.5" clearance between top of stub stack and the filter lid. I have 1.5" - 1.75" in the center, but toward the sides of the stack its more like 1".
Anyone else run one of these with a drop base and do they have with and w/o results from the track?
Where can I find a drop base cleaner that only drops about 1"?
Old 06-04-2007 | 01:56 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I don't have a stub stack, but came across similar issues with the Proform mainbody on the 396 with a factory air cleaner. Only had about a 1/2" of clearance. I added an air horn spacer to compensate.
The open element drop base air cleaners I've had were around 1-1/4".
Old 06-04-2007 | 11:00 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Re: K&N stub stack
This drop base is 1-1/4". With those air horn (air cleaner) spacers, do you have to use two gaskets, one below and one above the spacer?
If so, this will help me out cause I want to space 3/4", but found a cheap 1/2" spacer.
Old 06-05-2007 | 12:43 AM
five7kid's Avatar
Engine: LS1/LQ4
Yes, one gasket below and one above the spacer.
BADNBLK
Convertibles
65
02-10-2016 04:36 PM
efiguy
09-27-2015 02:30 PM
theurge
08-21-2015 01:46 PM
88'camaro305TBI
Carburetors
11-02-2002 10:42 AM
CamaroMike
Aftermarket Product Review
24
12-11-2000 11:15 PM
