dual snorkel swap -Anybody Know?
Please help, does anybody know if you can correctly fit and swap a dual snorkel intake from a 85 Camaro 5.0 to my 87 trans am 5.0 w/4bbl? If you do know you can also email me at rfracin@hotmail.com.
help
help
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can... those air cleaners should fit any carb aside from the dual-feed Holleys. The float adjustment nuts are too tall on those. All other carbs are ok though, far as I know.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I believe the question is whether it will fit under the hood, not whether it will fit on the carb.
The 'Bird L69's had a different type of air cleaner that used the cowl via the hood for the "2nd" source of cool air.
Received 1,720 Likes
You can stick it on there, sort of; but there are issues.
The snorkels get their air from the headlight pockets. No such thing exists on the Bird nose.
Axle/Gears: 9-bolt/3.45
In 1985, the new TA hood(twin louvers) was flat like the standard hoods, yet L69s were under them. And look at the pic of tsibouky's air cleaner, posted in this section regarding his new L69 car. It's not the same lid as was used with the functional cowl hoods. It's like the lid used on the Z28. Yet his car is a 1985 TA.
So the dual snorkle air cleaner apparently does fit under Firebird hoods. It prolly wasn't as effective on the TA as it was on the Z though, because like was pointed out, the Firebird didn't have the open space from which to draw fresh air like the Camaro did. Similarly, LG4 and TBI engines in Firebirds had single air inlets, and they were also under flat hoods, not cowl hoods.
But regardless, the airflow with the dual snorkle is obviously still much better than with the single inlet air cleaners, no matter which car it is on.
Engine: LS1/LQ4
That's true for 1983 and 1984 when the "power bulge" cowl hood was used. But that hood was retired after the '84 model year and wasn't brought out of retirement until 1987, when it was used on the Formula.
Car: 84 trans am
Transmission: built 700r4
so wait were the "power bulge" hoods availible on any trans am before 84 then? i thought that was only avalible on formulas, and i did know later model formulas didnt have a functional scoop like the eirlier ones.my 84 TA has a functional scoop hood but i dont know if its original. would modifying the intake for dual side hoses on top of the above air induction work? i dont see where you would route the other hose unless you were to run it down to below the car for a home made ram air.
I'd guess you could have the dual plus the top too, but I don't really know. You'd definitely get plenty of air with a set-up like that.
Brinkkl2000
08-04-2018 08:29 AM
