Idle Problems!
Idle Problems!
I have a Holley 650 with a vacuum secondary sitting on a 350, I have a 700r trans with a 2700 stall converter. I set my idle at 1050 runs good, tachs well but when I put it into gear my idle drops to about 550 and the car nearly stalls when I blip the throttle it does stall. I had to run my idle up to 1400 to correct this but it sounds way too fast. What should my idle be in gear and in park? Any ideas? Thanks
I have stock rebuilt heads, I have a crane roller cam 429intake 452 exhaust/gross lift 260/270 duration, hooker cat back exaust, edelbrock shorty headers 1 5/8 I believe. edelbrock performer rpm intake
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
First, make sure the ignition is working properly. Are you using a stock computer controlled distributor, or one with vacuum/mechanical advance?
If that's up to snuff, check for vacuum leaks.
I have A new HEI distributor The only vacuum lines I have are one to the distributor advance, one to the brake booster, I checked those. I have not driven the car since I built the motor and changed to a carb. But I did have it idling properly at one time.
Engine: LS1/LQ4
What changed between the time it did idle correctly and when it stopped idling correctly?
Engine: LS1/LQ4
The temp change probably doesn't have anything to do with it.
I'd suspect something with your base gasket, either leaking, or blocking something it shouldn't.
I reused the old gasket it looked fine but maybe the carb didn't seat like it was the first time. I really appreciate All of your help, I'll get a new gasket and go from there.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
get the new gasket in? nows a good time to verify your transition slots? you have the secondary throttle plates cracked open any?
