holley trick kit??
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
holley trick kit??
So i have a mildly tuned 350sbc with a holley 600 cfm that needs a rebuild. Im curious what is the difference between the renew kit and teh trick kit? besides 60 bucks. is it really worth it? or will it just be a waste. funds are tight for me right now so i'd like to save money if possible, unless the trick kit is totally worth it. thanks
~JAKE
~JAKE
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
the trick kit just comes with more parts, secondary springs, cams, squirters, and I think even some extra jets...basically more of the stuff needed to fine tune your carb. I thought about buying one also, but like you noticed, they are pretty pricey.
Car: 87 pontiac fiero
Engine: 2.5 liter
Transmission: 5speed
Axle/Gears: dont care.
the trick kit is pretty pricey, most likely youll put in some bigger jets, maybe a lower power valve, and be happy with it, and not what to take apart your carb again and change stuff, so theres the wasted money on the trick kit. lol.. unless you like to change stuff all the time, have a normal driver one day and a strip car the next......
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
86CamaroDan
09-29-2015 10:08 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
