throttle and tv cables for carb.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
If I switched to a carb setup from tune port will I need different throttle and tv cables? If so what kind?
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
I am in that process right now and am kinda wondering the same thing but I am not sure yet I will know here in a week or so when I have a chance to work on the car. I am thinking yes I am going to have to go to an aftermarket cable but not really sure. There is someone that sells kits for swaps like that but I cannot remember the name we have bought stuff like that for cars that we have done at the shop but I will have to look on who makes them.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Find carb cables. Not too hard to do. Or, TBI are also shorter than TPI and can be made to work.
Car: 1990 Camaro
Transmission: 4L60
Holley Numbers
Part Number are 20-95 Kickdown Lever GM 700R4 AOD
and then Holley # 20-121 Overdrive Kickdown Bracket to be used in
conjunction with / 20-95.....they work rather nice and you get corrected
fitment of cables...
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
brandon when did you get s/s lines for that DP? ill have to come check it out sometime this week
TheTraut88
09-07-2015 05:22 PM
