Finally Completed Engine
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Ok, for all of you that have helped me over the past couple of weeks with questions about this 305 engine, here it is, i think it turned out very well, take a look!
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Just kidding around man, it does look good. What are the numbers on the heads, cam, etc? What kinda power are you hoping for? Looks great, I bet your excited to fire it up.
Car: 1989 Camaro RS
Your right, the color is Old Ford Blue, hey i dont care what the name of the color says, i just go for the color!
LG4 305
-Crane Cams XtremeEnergy Cam XE256H-12
-Edlebrock Performer Airgap Intake
-Summit 1.5 Roller Rockers
-Holley Reman. Q-Jet
-New lifters
-Heads machined (not sure of head numbers. Machine shop did the works to them though, new stainless springs good to 650 lift, ground valves and cleaned ported valve ports, this shop was setup to do race car heads when I dropped mine off so thats what they got. Shop guy said I should be around 9 to 1 compression)
-Edelbrock Headers
-High volume oil pump
-High Flow Carter Fuel Pump
-Some chrome stuff
-Engine cleaned and painted Old Ford Blue
Not sure what kind of power I would be getting out of it, maybe some one would be able to give me a ball park. Thanks for looking guys!!
LG4 305
-New lifters
-Edelbrock Headers
-Some chrome stuff
1 Post
Car: 1986 Camaro SC
LG4 305
-New lifters
-Edelbrock Headers
-Some chrome stuff
LG4 305
-New lifters
-Edelbrock Headers
-Some chrome stuff
Mine's a good base, I'm probably going to go with some better or ported heads, and maybe some more cam to get the power up past 260hp, and then spray it. Its already got a shift kit, 2500rpm stall, and 3.73 posi rear, so it just needs a little more power.
Terrell351
06-13-2021 01:13 PM
